Results 1 to 3 of 3
    Apr 2013
    Noob... Need the right chainset bolts!
    Hi
    I need some new chain/crankset bolts for a 2010 trek fuel ex 8. The crank is a deore XT, but im confused about single/double triple bolts etc... anyone know what model of bolt i need??
    thanks
    Dec 2004
    I assume this is for the outer two chainrings? If so you'll need double bolts, unless you have removed the outer ring. In that case (where you are securing the middle chainring only) you'll need single bolts, which are slightly shorter.
    That being said, check Universal Cycles: Universal Cycles -- Shimano Chainring Bolts
    You should be able to get the exact match for what you have now (XT model 770 perhaps?), as long as you are staying with 3 chain rings.
    Dec 2004
    I forgot to mention - I'd recommend installing chainring bolts using Loctite 243.
  1. Call me what you want - looking for a 22,32,42 chainset.
    By Damitletsride! in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-04-2012, 03:10 PM
  2. Replies: 1
    Last Post: 02-28-2012, 08:14 PM
  3. Noob ? on chainring bolts
    By Glynn Sluder in forum Singlespeed
    Last Post: 02-22-2012, 10:03 AM
  4. SL-R Chainset Compatability
    By Tofu in forum Ibis
    Last Post: 01-30-2012, 01:54 AM
  5. New Chainset / Crankset
    By PistonShins in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 03-10-2011, 10:38 AM
