I-Spec mix and match?
I've looked at the shimano docs but haven't been able to figure it out.
I have a pair of XTR BL-M985 brakes. I want to use the i-spec SL M780 XT 10 speed shifters. Would I need the XT or XTR I-spec piece? Or will it not work at all? Thanks in advance!
You need to match the I-spec brackets to the shifters which should be the SL-78 I-spec brackets.
Do you already have the shifters? Your post is a touch confusing. If you have xt shifters then follow what I said above.
If you're buying shifters then the ispec version of the xt shifters will mount to the xtr brake levers no problem.
what abt xt ispec with saint brake levers?
Yep fully compatible with ispec shifters.
- You may not post replies
- You may not edit your posts
Forum Rules
