Results 1 to 9 of 9
    Titanium is for real
    Freehub removal XT M775 wheel
    Hi,
    I need some help to remove my freehub body one my XT M775 wheel. It is completely stuck i tried on the tube, but i canīt find anything suitable. I dont have the drawings of the hub
    Thanks in advance
    Kristian
    Quote Originally Posted by morbergsmed
    Not sure what you're referring to here.
    Anyway, here is the drawing. Not the exact same hub as the M775 wheelset, but I'm sure the internals are the same:
    http://techdocs.shimano.com/media/te...9830646671.pdf
    You need a cone wrench to remove the axle (#3). I think it's 17mm. Then you need a 14mm hex wrench to remove the Body Fixing Bolt (#8).
    Instructions:
    http://techdocs.shimano.com/media/te...9830621150.PDF
    ups and downs
    Here's the WH-M775 diagram, functionally it's the same as the XT rear hub diagram.
    Reputation: shiggy's Avatar
    Dec 1998
    Quote Originally Posted by spsoon
    Instructions:
    A 17mm cone wrench and a 5mm hex to remove the axle. The "end cap" is the lock nut and you insert the 5mm into the end to turn it.
    mtbtires.com
    Hi again,
    I have now removed the freehub. Is it possible to disassemble the freehub itself or is just a replaceable item?
    The freehub will not turn at all. Is it a solution to put in a bath of some kind of degreaser?
    and then of course regrease it again??
    Thanks in advance
    Kristain
    Reputation: gticlay's Avatar
    You'll need a new one.
    "It looks flexy"
    Positively negative
    Hi again,
    Thanks in advance
    Kristain
    It is possible but not worth it. Morning Star sells a tool called the free hub buddy to clean and lube the internals, but honestly it may be easier and faster for you to just replace it as clay said.
    oops, posted in wrong thread.
    Klunkin' Ain't Easy.
    Reputation: sjordan72's Avatar
    Jan 2005
    FH just blew up after 3 months. I was having issues with the hub loosening up so my shop replaced ALL the hub internals and freehub. I have been loving the Shimano UST rims but now that Mavic has released the 821 disc rims, these XT wheels are headed to the swap meet (after I replace the FH again.) The shops know these FHs stink and most have spares on hand. I called Shimano and they started asking if I had broken spokes, was the wheel detensioned then retensioned when spoke was replaced...I asked if they had thought about maybe ditching a clearly flawed FH and redesigning and they said I should send my wheel in so they can examine it. I may just do that after I build up a set of Chris King/821 wheels.
    Obviously, you're not a golfer.
