Results 1 to 13 of 13
    Mar 2006
    Free Stroke During Bleeds?
    What setting should you have the free stroke screw at while bleeding 2011+ brakes?
    More free stroke = more available volume right in the reservoir?
    Reputation: Dover's Avatar
    yep, i agree with that.
    if the screw is out it allows for more oil volume
    Mar 2006
    So if you bled with a good amount Of free Stroke and then later reduced the free stroke, would the extra oil in the system put stress on the seals?
    staike
    Reputation: staikeinthahood's Avatar
    If I turn the free stroke all the way out, bleed the brakes and then turn it in, will the brakes be super tight?
    how about the reach adjuster setting, all the way out or in?
    Diggity Dog
    Reputation: ShinDiggity's Avatar
    Shimano's bleed process specifically indicates to start at the factory settings which is free stroke all the way in and lever reach all the way out.
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Quote Originally Posted by OGWGFIWRT View Post
    Avid Elixirs say to do the same (Pad contact adjust on Avids), put it all the way in. I did it this way a couple years, finally tried bleeding with the stroke adjust halfway and it worked much better.
    With the greater volume it made the stroke adjust actually do something to adjust both ways, the brakes are much more tunable now.
    I'd imagine the same principle applies to Shimano, I don't know why both companies recommend otherwise. Hasn't caused any problems for me in the six months since my last bleed.
    "...like sex with the trail." - Boe
    staike
    Umm... how does it matter what the reach adjust is at?
    nocturnal oblivion
    Mar 2006
    Quote Originally Posted by staikeinthahood View Post
    They probably just don't want you to bleed with the lever all the way in. It'd make it tough to fill the reservoir properly when releasing the lever and adding fluid.
    Aug 2010
    Nope! I tried exactly that and nothing happened. I'm starting to think that 'free stroke' actually means 'free screw'. What Shimano has done is stuck a free screw in the side that sits there and lets us all have fun screwing around (ba boom) with no affect at all.
    staike
    Haha, thanks though.
    Reputation: 702Biff's Avatar
    Dec 2012
    Jan 2014
    Quote Originally Posted by half_man_half_scab View Post
    Unscrew it to release any bubbles then screw it back in before you put the bleed screw back in.
  1. XTR free stroke adjustment
    By pachaven in forum Brake Time
    Last Post: 03-02-2011, 07:57 PM
  2. XT Disks, Free Stroke?
    By Tinshield in forum Brake Time
    Last Post: 11-30-2008, 01:59 PM
  3. XT 2008 Free Stroke Adjust not really working
    By dmalovic in forum Brake Time
    Last Post: 08-14-2008, 11:58 AM
  4. XT 2008 Free Stroke Makes Me Sad
    By Dogdude222 in forum Brake Time
    Last Post: 03-23-2008, 03:03 PM
  5. What`s is Free Stroke?
    By fran in forum Brake Time
    Last Post: 12-05-2007, 08:56 AM
Members who have read this thread: 22
