Results 1 to 11 of 11
    Reputation: mtbj's Avatar
    Does this come off. XTR Brake Calliper.
    Does the part in the pic come off? If so do i need any seals when i replace it?
    Attached Thumbnails Attached Thumbnails Does this come off. XTR Brake Calliper.-brake-arrow.jpg
    Reputation: Dover's Avatar
    NO,
    dont remove that
    Does it come off at all. I would really like to get it anodized.
    Reputation: fallzboater's Avatar
    Quote Originally Posted by mtbj
    You have got to be kidding. Why don't you color it with a Sharpie?
    Try it. If you want to ano it that badly, give it a try and let us know how it goes back on. I'm interested to see how the piston and seals look like from inside. Pistons are inserted from here with seals. Removng the nut will probably distroy seals though - so be sure to have spare seals on hand. I'm curious how it comes apart.
    Could you just have them ano the part while still on the brake?
    Reputation: boomn's Avatar
    Quote Originally Posted by CHSAD
    Since anodizing involves submerging the part in an acid bath, no I don't think that would work
    nope,
    that blt threads inward not outward. if you start to loosen it it will go in not out.
    I tried and f'd up my brake
    Quote Originally Posted by Dover
    If it threads inward is it some type of adjsustment for the pad? Why would they put a torx head on it? it cant be just for decoration can it?
    I assume that is there from the factory assembly..
    do NOT remove that piece. that is how the caliper is assembled (not a pad adjuster) from the factory and is not meant to be taken apart. there are no seal kits available if you do open the caliper.
