Results 1 to 2 of 2
    Mar 2011
    Crank Puller (pics) - Which one?
    (you can see right thru to the other side)
    Do I need this one
    CCP-22C
    Fits all cranks using 22mm x 1 threads and square, tapered bottom bracket spindles. Also fits "Power Spline" cranks from SRAM using the 8mm thread bolt.
    OR this one
    CCP-44C
    The 22 x 1 mm fine thread.
    For crank bolts larger then 8mm threading. ISIS Drive and Shimano Octalink may use either 12mm or 15mm bolt thread.
    I looked more clearly and it looks like I have the octalink... (the ridges around the thread that look like a torx driver)
    Jan 2009
    yep octolink. Says so on the crankarm although it rubbed off a bit. This is the model that came with my bike. Its a Fc-5 series crank.
