Results 1 to 3 of 3
    Reputation: stepping-razor's Avatar
    crank/cassette compatibility
    hi
    i plan on going from xt 770 triple cranks to slx m665 doubles. i have an xt 770 9 speed cassette and an xt 770 front derailleur. will i have any shifting or chain problems for compatibility reasons?
    thanks
    Be yourself. Everyone else is already taken.
    ups and downs
    As long as it's all 9 speed you're fine. Although you might find an advantage to switch the FD to the 2 ring FD-M665 front derailleur as the cage sits lower and is closer to the bashring.
    Quote Originally Posted by rockyuphill View Post
    yes. thank you rocky. i figured that might be the case. definitely going to check into it.
