Results 1 to 3 of 3
    Combining LX 9sp w/ 8sp?
    I'm as bemused as one can be. Currently, I have a bike that runs an 8sp cassette with a standard triple ring setup. The bike is in the process of a complete drivetrain overhaul.
    My question is, can I run an LX rapid rise 9sp rear derailleur with an 8sp cassette, shifters and chain, using standard LX hollowTech cranks?
    Much appreciated.
    Reputation: Ronnie's Avatar
    Quote Originally Posted by zredbullz
    Much appreciated.
    I've never tried it but logic says that there should be no problem. The 8 speed indexing is controlled by the shifters. Post your question again on the "Everything Drivetrain" forum. You'll probably get a confirmation.
    Ronnie.
    The trouble with having an open mind is that people will insist on trying to put things in it.
    Reputation: Dover's Avatar
    you wont have a problem. the indexing is done at the shifter and the limits are the same for 8 and 9 speed so the RD has the ability to move from one side of the cassette to the other.
