Results 1 to 5 of 5
    Reputation: eurospek's Avatar
    Can I use Shimano M665 SLX 2x9 cranks with 2x10 chainrings?
    I want to give 2x10 a try on my next bike but would like to stick with the proven and toughened up Shimano SLX M665 cranks that I'm currently using 2x9 on. If I buy the SLX 2x10 chainrings for them, will it be a doable swap or do I need 2x10 specific cranks?
    konahonzo
    whistler
    all the new "10-speed" chainrings use the same 64/104 BCD as your cranks except for XTR "race".
    you could just replace your middle ring with a 34 or 36 and the big ring with a light bash guard (or nothing, just washers to space out the chainring bolts).
    Reputation: beer_coffee_water's Avatar
    Mar 2011
    You can run the M665 crank with 9 spd rings and still have a 2x10. My bike is 9 spd up front, crank and FD, and 10 spd out back, shifters (3x10 pods), chain, cassette and RD. Basically it is a 2x10 SLX Dynasys drivetrain. You shouldn't need to change out the rings unless they are done.
    Mar 2011
    I am running the M665 double crank with a 24tooth 10spd little ring and the 36tooth 9spd big ring that come with the M665 crank. I am using Dynasys 10spd shifters and derailleurs without any issues...
    May 2012
    I'm running the M665 setup also and want to convert from 2x9 to 2x10. I have the following parts on the bike:
    1. 2011 SRAM X9 Shifters
    2. 2011 SLX 665 FD-E
    3. 2011 SLX M665 Crankset 22/36
    4. 2011 SRAM PG-950-9 11-34T
    5. 2011 SRAM X9 RD
    6. 2011 SRAM PC-951Chain
    What do I need to buy other than:
    -10 Speed Shifters
    -24tooth 10spd little ring
    -10 speed RD (thinking about a Shimano XT or SRAM XO RD)
    Do I need washers to space out the chainrings? Also, I've heard a 10speed chain is thinnner and will reduce chain rub.
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/gVmPN5d94E7-Obi3tOZkrtMTjNZETYmyPJy0liipFm0?feat=embedwebsite" ><img src="https://lh6.googleusercontent.com/-ApoWcn7dbuY/T7GCKmzGh2I/AAAAAAAAAAc/oY6EXmLy0sU/s144/photo.JPG" height="144" width="108" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/117496295110923396157/May142012?authuser=0&feat=embedwebsite">May 14, 2012</a></td></tr></table>
    <table style="width:auto;"><tr><td><a href="https://picasaweb.google.com/lh/photo/ZZVaVWuxLUIFcdiKXFf02tMTjNZETYmyPJy0liipFm0?feat=e mbedwebsite"><img src="https://lh6.googleusercontent.com/-M29WSn-Xnwk/T7GCOmnyTAI/AAAAAAAAAAk/vCT46tf5rRo/s144/photo1.JPG" height="144" width="108" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="https://picasaweb.google.com/117496295110923396157/May142012?authuser=0&feat=embedwebsite">May 14, 2012</a></td></tr></table>
  1. Can I use Shimano M665 SLX 2x9 cranks with 2x10 chainrings?
    By eurospek in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 09-09-2011, 09:15 PM
  2. 2012 Shimano XT 2x10 Cranks
    By Shalom in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 08-09-2011, 12:47 PM
  3. Will Shimano XTR chainrings work on SLX Cranks?
    By Thrasher in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 05-04-2011, 09:45 AM
  4. Chainrings for Shimano HTII cranks?
    By Entrenador in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 02-17-2010, 04:17 PM
  5. New Shimano XT Cranks - Only Shimano Chainrings fit?
    By Little Willy in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 06-15-2009, 11:55 PM
