Results 1 to 6 of 6
    Reputation: jrsbike's Avatar
    Caged ball bearings vs loose on rear hubs
    My XT M775r rear hub has caged ball bearings on the brake side and loose balls on the drive side. I experimented and found that a caged set can work on the drive side. Why doesn't Shimano do this? I think they are all 3/16 balls.
    Enthusiast
    Reputation: JonathanGennick's Avatar
    I like my balls loose. Cages, I believe, are only there to simplify the production line on which the hubs are made. Imagine paying someone to stick in tiny balls one at a time versus sticking in a cage and being done w/it.
    Reputation: Joules's Avatar
    Yeah, cages are just for ease of assembly, and to ensure that you put the right number of balls in.
    Enthusiast
    Quote Originally Posted by Joules View Post
    Except that one needs to put in more balls without the cage.I think I get what you're saying though. One doesn't want assembly line workers counting out loose balls. There would be too much opportunity for error.
    My balls are caged up almost all day so I lose balls sometime. I also don't mind when they are lubed and handled.
    nocturnal oblivion
    Reputation: stumblemumble's Avatar
    Mar 2006
    Probably has to do with the added torque of the brake side. I prefer caged myself because I'm lazy and born with good looks; Many prefer loose because if adjusted properly they'll last forever.
    "...like sex with the trail." - Boe
  1. Replies: 10
    Last Post: 09-05-2014, 10:00 AM
  2. Ceramic bearings for loose ball hubs?
    By One Pivot in forum Wheels and Tires
    Last Post: 12-06-2009, 06:11 PM
  3. Headset caged ball bearings
    By greb in forum Tooltime
    Last Post: 10-13-2009, 08:34 AM
  4. loose rear hub bearings
    By AlexJK in forum Wheels and Tires
    Last Post: 08-11-2009, 04:47 PM
  5. bendix 2 spd overhaul with loose ball bearings? good/bad?
    By azdirtgod in forum Vintage, Retro, Classic
    Last Post: 05-13-2007, 07:31 PM
