Results 1 to 5 of 5
    New question here. Brake Lever/ Caliper compatability
    Are the older XT levers BL M756 compatible with the 08 XT and 07 XTR calipers?
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    yes they are... just need to use the appropriate fitting/hose
    http://bike.shimano.com/publish/cont...nation.pdf.pdf
    I live to bike
    Reputation: Jwiffle's Avatar
    But why? It's the new 08 XT brake levers that have the servo-wave cam. if anything, use older calipers with the new levers!
    Quote Originally Posted by Jwiffle
    Exactly my thoughts (and plans )
    wyrd bi ful rd
    Reputation: chinaman's Avatar
    Anyone know what type of steel braided hose I can use with XT calipers and levers?
    Am I correct to assume that hose size is usually standard and I will be able to just use the current fittings and so all i need is a new hose?
    I have had a look at my XT765s and noticed that for the post mount, the front and rear is the same?
    Cheers. Sorry Kauia for hijacking this thread.
