Results 1 to 2 of 2
    Proud 2 Times BOTM Looser
    Reputation: badbushido's Avatar
    New question here. banjo bolt for BL-S500
    Is there a banjo bolt available for Shimano brake-levers?
    I need to do a 90 connection to an Alfine lever BL-S500.
    If there's no Shimano item, which Goodridge kit might fit?
    Wanted M A N T I S Stem
    ___________________
    OLDSCHOOLRACING
    Reputation: Wombat's Avatar
    I think the lever has to be designed for a banjo. The old M-755s used a banjo and when they changed to an in line connector they redesigned the lever to the M-756. I assume it's the same for other levers.
    So you might have to find a lever designed for a banjo.
    Tim
