Results 1 to 2 of 2
    Any way to use XTR BR-965 front caliper on rear?
    I ended up with 2 XTR BR-965 front calipers and was hoping to make them work as a front/rear pair somehow. These are IS mount calipers. It appears that the rear version would have a longer back "leg" to properly mount to the frame. I have seen a lot of adapters, but the IS-IS ones all seem to focus on using different brake rotor sizes and don't seem like they would solve my problem.
    The frame is a 2005 Specialized Epic and the current brakes are Avid Juicy's that are post-mount with IS-Post adapters.
    Anyone know of any adapters that could make this work? If I can avoid having to buy a rear caliper and sell a front, that would be great.
    ups and downs
    You can use the front caliper on the rear with a 140mm rotor.
    Or you can use a 160-180mm IS-IS front adapter on the back with a 160mm rear rotor. Those are likely to be hard to find in stock anywhere, but they do exist.
