Results 1 to 6 of 6
Thread: 7in Rotor
    Reputation: paneristi's Avatar
    7in Rotor
    I see that the new Kona Coilair gets 7in Shimano Rotors.
    Are they new products?
    Do Hayes caliper adapters & rotors fit Shimano Saint (or XT)?
    Thank yall
    Reputation: Dover's Avatar
    7 in rotor
    Quote Originally Posted by paneristi
    Thank yall
    yep. hayes adapters are the same as shimano except a little heavier but they dont make a 7" version.
    err, 27.5+
    Reputation: AL29er's Avatar
    Looks like Shimano is bringing back the 180mm rotor. 6-bolt and centerlock rotors as well as the appropriate adapters will be available for 2007. No need to run other companies adapters, unless you already have them. In that case they should work fine.
    Nightriding rules SuperModerator
    Reputation: crisillo's Avatar
    They have been available for the past year, I already used a 180mm LX/Hone centerlock for 6 months on my XTs, before switching hubs 5 months ago...
    They are available in centerlock at the LX/Hone level and in 6 bolt at the XT level.
    There are also the corresponding adapters available:
    SM-MA-F180P/S: front PM to IS
    SM-MA-F180P/P: front PM to PM
    SM-MA-R180P/S: rear PM to IS
    Quote Originally Posted by Dover
    Hayes does have a " 7" version" (I am not sure if it is 180mm or 185mm though) The rotor is called the V7 and the adapters are available too.
    Ah.. I forgot... I am running a 180mm rotor in the rear of my 575, here is a pic of the rear Shimano adapter (it is a hope rotor though)
    <a href="http://www.flickr.com/photos/cmadrigal/314120733/" title="Photo Sharing"><img src="http://static.flickr.com/103/314120733_6189fc59f9_o.jpg" width="800" height="600" alt="180mm rear disc brake" /></a>
