Results 1 to 6 of 6
    kabouterclan member
    Smile 22t inner ring on FC-M980: fits perfectly!
    EDIT:
    After reading the replies below, i bought and mounted a m970 22t ring.
    Fits and shifts perfectly!
    The offset difference is just ~0.4mm, nothing to worry about.
    Thanks for the replies.
    Sent from my HAL 9000
    Reputation: Surfas's Avatar
    Try the XTR M970 22t.
    kabouterclan member
    Quote Originally Posted by Surfas View Post
    Thank's, i might give it a try.
    Also found this one...
    Blackspire SuperPro Chainring - Shimano XTR FC-M980 2012 | Buy Online | ChainReactionCycles.com
    Epic rider
    Reputation: rapsac's Avatar
    Sep 2004
    Did that with my crankset, works perfect.
    Verstuurd van mijn GT-I9100 met Tapatalk
    12 Anthem X29
    13 XTC 29
    07 Epic Marathon carbon
    04 Stumpjumper FSR Anniversary
    03 Stumpjumper FSR Pro
    00 Rockhopper Pro
    kabouterclan member
    Check, it does :-)
    Oct 2012
    No good Be careful of the 14t rule...38-22=16>14!
    Hi,
    ...I did this with my XT 2x10, and I ended up sucking the chain into the shadow + rear derailleur when stomping on it and shifting down on the rear cogs. I weigh 230 and am riding a SC Tallboy LTc, likely my suspension movement caused the chain to be loose enough to whip and get sucked into the cage and it basically sheared the XT M785 RD in two, destroyed the cogs, broke a spoke and may have tweaked the solid derailleur hanger.
    If you keep the 22t you'll want to go down on the outside to a 36t at a minimum.
    Good luck!
