Results 1 to 12 of 12
    Reputation: packfill's Avatar
    Aug 2005
    2011 M980 XTR PF30 cranks???
    Is there such a thing? anybody? anybody?
    Reputation: Dover's Avatar
    do you mean BB30. Shimano doesn't make any BB30 cranks
    Aug 2005
    Press Fit 30. There's a difference.
    whats the difference?
    Aug 2005
    oops.... there's no difference in the cranks, just the bottom bracket. sorry for the confusion.
    Aug 2005
    ...my confusion.
    Raceface do a step down press fit bb30 bottom bracket to work with their 24mm axle cranksets, i expect this would also work with shimano cranksets.
    http://www.raceface.com/components/b...-type-adapter/
    Dec 2010
    SRAM also makes a press in adapter for PF30 shells to make them threaded bb compatible
    EDIT: I kind of doubt Shimano will make a 30mm spindle crankset, they seem to be quite against it because they say it is not any stiffer. I think the biggest benefit to PF30 is the increased stiffness from the added real estate for the downtube to weld on.
    Jan 2009
    I am about to order Niner Air 9 frame with PF30 BB, and where can I buy an adapter for use of Shimano XT/XTR crankset, either for press fit (73 mm BB width) or for ordinary threaded BB?
    You can use wheels manufacturing step down adaptor without changing bottom brackets.
    Wheels Manufacturing - BB30 Products
    The easiest is this adapter SRAM PF30 to BSA which allows you to thread in the standard Shimano BB cups. I have used it and it works great.
    PF30 has 46mm inner diameter. Its different to Pressfit which its in-dia 41mm or 42mm.
