Results 1 to 7 of 7
    Jun 2010
    11-36 and saint shadow plus... anyone running this setup?
    Anybody running the above setup? would love a short cage mech and saint looks amazing but need to keep my 11-36 cassette, so will saint work with such a wide range cassette in the fr mode?
    11-36 works
    im running the Zee 11-36 works great!
    Oct 2010
    How about suspension movement and chain growth? If chain is long enough so you can bottom out your rear shock when the chain is on 36t ring is the chain still tight enough when on 11t?
    Reputation: OCMoto's Avatar
    Been running the Saint Shadow+ setup on my Uzzi 1x10 with an 11-36 cassette and it works flawless so far. No issue throughout the entire range.
    Reputation: Dover's Avatar
    you have to install the mode convertor. (little black thing on the back) and only use a single ring up front. it'll work for sure.
    Reputation: Shalom's Avatar
    Nov 2008
    Saint can do both narrow and wide (mode converter, as stated by Dover). Zee you have to choose which you want and get the appropriate derailleur for your setup (no mode converter).
