Results 1 to 6 of 6
    10sp crank + 9 sp setup?
    will the 10speed dynasys crankset work with a 9 speed system? I have a 9 speed (22x34xbash) setup but want to change the crank to a 10 speed dynasys ( XT or XTR ) but I want to make sure it will work with my 9 speed system.
    I only use the brake, so I can accelerate all over again...
    ..:: www.THELOBBY09.com ::..
    im using sram gripshifts 9 speed x9 and just replaced the cranks to xtr race 2 ring 10 speed cranks.
    using the old kmc 9 (not stretched) speed chain and xtr rear cassette.
    so far so good.
    Sorry, looking in the forum but I did not find a answer. My crankset broke ( Shimmano M770 9 speed) , does M780 10 speed crankset will work fine? All the drivetrain is XT 9speed. Has any one tested it?
    thank you
    More Torque
    Reputation: Diesel~'s Avatar
    Quote Originally Posted by Leomtb View Post
    thank you
    It should be fine, especially given that the rest of your drivetrain is 9 speed.
    Not the exactly same, but I've run the following combos with great shifting:
    Shimano 10 speed road cranks with 9 speed drivetrain
    Shimano 9 speed mtn cranks with 8 speed drivetrain
    Shimano 9 speed mtn cranks with 10 speed drivetrain
    Shimano 10 speed everything (including cranks), with 9 speed chainrings
    There are some sweet deals on SLX cranksets if you are looking to save a little $. It is my understanding that the weight and performance are nearly identical to XT.
    -D
    Quote Originally Posted by Diesel~ View Post
    -D
    Thank you Sir, now I will look for a nice deal
    I Tried Them ALL... SuperModerator
    Reputation: Cayenne_Pepa's Avatar
    Shimano 10-speed, 2 x 10 crank works well, with 9-speed. Get even quicker front shifts and go 10-speed front derailleur, with a XTR/Dura Ace 10-speed chain - for many benefits of 10-speed...with one less gear!
    "This is a male-dominated forum... there will be lots of Testosterone sword-shaming here" ~ Kenfucius
