Results 1 to 5 of 5
    09 XTR Crank Questions
    I am trying to take my cranks apart for the first time but can't figure out how to get the left arm off. I have worked on XT a lot but these cranks are much different. Please help.
    BC
    ups and downs
    You need the removal tool which acts as the self extracting cap. Here's the manual
    Is that tool something I can get from the LBS or do I need to go to Shimano?
    BC
    ups and downs
    The LBS will have one if they're ever installed XTR cranks, that's likely the easiest thing to do, just have the LBS remove the arm, you don't need the tool to reinstall it.
    You can buy the tool.
    Thanks for all the help.
