Results 1 to 2 of 2
    MTB Owner
    Reputation: C-Rock's Avatar
    Nov 2006
    03 XTR disc brakes
    Does anyone have service experience(s) with the 03 XTRMultishifter/brakes??
    Lately the front brake won't lock up the wheel. The lever is not bottoming out and is "stiff" as it should be in the PDF/manual. There are no leaks at the caliper or lever or lines. There is NO contamination of rotor or pads (scrubbed rotor with alcohol-new pads).
    At first the inside piston wasn't working well (was a little "stuck" retracted)..but now it works smoothly and evenly with the other side's piston. It just won't lock up the wheel.
    Does anyone have service experience(s) with the 03 XTRMultishifter/disc brakes??
    MTB Owner
    Nov 2006
    Got It Right
    Although there were no responses, i found lots of info on THIS site!!
    Combined with Shimano's PDF for these brakes, and my LBS tech, the problems i was having are gone, and i'm now enlightened about maintaining 'em.
    I know XTR isn't the most rugged stuff, but then again, it was never said by Shimano, or anyone else i know, that XTR is about being "bombproof".
    I still appreciate the "watch-like" precision and low weight of XTR.
    (However, my next build will be something else,
    ...just to keep things interesting and fresh )
