Results 1 to 2 of 2
    new
    new is offline
    May 2012
    What is my Sette Flite worth?
    I've got a 2009 Sette Flite that I no longer ride and I'm considering selling it. It's completely stock, I'll include the build kit below. And it's in excellent shape with no large scratches and no dents. Just curious on what I should ask for it.
    Aluminum 6061
    Size(s) Small (17"/43cm) / Medium (18"/45.5cm) / Large (19"/48cm)
    Fork Rock Shox Domain 318 Coil (6.3"/160mm)
    Rear Shock Rock Shox Monarch 3.1 (6"/152.4mm)
    Shifters SRAM X7, 9-Speed Trigger
    Front Derailleur SRAM X7, Low Clamp, Blk, 34.9 Top Pull
    Rear Derailleur SRAM X7
    Shifter Cable/Housing Jagwire Slick
    Brake Levers Avid Juicy 3
    Front Brake Avid 185mm Rotor
    Rear Brake Avid 185mm Rotor
    Hoses Avid Hydraulic Hose
    Crankset Truvativ Stylo 3.3, 175mm, Black, 44/32/22T
    Bottom Bracket Truvativ Stylo 3.3, 68mm/English
    Cassette SRAM PG-970, 11-34
    Chain SRAM PC-971
    Headset FSA 1-1/8" Semi-Integrated/Internal - Black (Zero Stack)
    Handlebar Lightweight Alloy - Black
    Grips Durable Ergo Grips - Black
    Stem Lightweight Alloy - Black
    Saddle High Performance Saddle - Black
    Seatpost Lightweight 6061 Alloy - Black, 31.6 x 350mm
    Rims Mavic EX729 32H Black, Presta Valve
    Front Hub Sette 20mm Thru Axle, 6-bolt Disc Brake, 32H black, heavy-duty cartridge sealed bearings
    Rear Hub Shimano XT M756, 6-bolt Disc Brake, 32H Black, QR
    Spokes 14 Straight Gauge, Stainless Steel, Black
    Pedals Platform, Chromoly Spindle, Black
    Front Tire Kenda Nevegal 26" X 2.35, 60 TPI, DTC
    Rear Tire Kenda Nevegal 26" X 2.35, 60 TPI, DTC
    Color(s) White
    Warranty 5 Years
    Weight 34.8 lbs/15.8kg (w/Pedals, Medium Size Avg.)
    May 2005
    500-600
  1. What is a Sette Flite worth?
    By new in forum Sette
    Last Post: 06-13-2013, 05:01 AM
  2. A couple Sette Flite questions....
    By Shortfuze in forum Sette
    Last Post: 05-28-2011, 10:31 PM
  3. Sette Flite on PricePoint for $899.99 Until 4/30
    By imsorrywhat in forum Sette
    Last Post: 04-18-2011, 02:33 PM
  4. New Sette Flite Owner
    By Stealpulse in forum Sette
    Last Post: 04-07-2011, 04:48 PM
  5. Scott Voltage FR30 vs. Sette Flite
    By darkness777 in forum Downhill - Freeride
    Last Post: 03-31-2011, 09:25 AM
