Results 1 to 9 of 9
Thread: Sette Stem...
    Sette Stem...
    The stock stem on my Flite might be too short for me. I usually prefer the lower riding position.
    I'm thinking of getting a 110mm stem. Considering the Edge and the new Evo.
    Any experience with either stems?
    Any suggestions if the black or white stem would look better on the white framed Flite?
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    well, I think you've seen the edge on mine...
    here's a pic for anyone else tho
    Honestly... ahh I give up
    I forgot you had that stem!
    If I get one it shall be white...No way will I let your bike be "blingier" than mine!
    What's the length?
    ~Disc~Golf~
    80mm
    Short arms long legs!
    Reputation: Dremer03's Avatar
    I like the Evo, its on my list for when I switch off to a OS riser bar.
    Big Foot Blue KHS XC704r
    Highdelll is your stem the standard or the oversized model?
    I'm not sure which size stem will fit the stock Flite handlebar. But chances are I'll switch out the stock handlebar for a lighter one. Suggestions?
    ~Disc~Golf~
    it's 'standard' (25.4)
    It should be easy to tell what bar you have.
    the 25.4mm has nearly 0 taper, while the 31.8 has quite a noticeable taper.
    I like my MonkeyLite bar (150g)
    Quote Originally Posted by highdelll
    I was just looking at the monkey bar. No issues with rigidity?
    I know you're a little lighter than me.
