Results 1 to 2 of 2
    shining bright
    Reputation: cncwhiz's Avatar
    Sette Razzo vs Motobecane and Access offerings
    I'm in the market for a new 29er, and I have narrowed my choices to three "mail order" bikes. They are the Sette Razzo, The Motobecane fantom 29 Pro SL, and the Access XCL 9.7.
    I really like the Sette, but I'm just undecided on which to buy. These are the specs on each:
    Sette Razzo
    Frame Full 7005 Alloy, Double Butted Main Triangle
    Size(s) Small (16"/40.6cm), Medium (18"/45.7cm), Large (20"/50.8cm), X-Large (22"/55.9cm)
    Fork Rock Shox Reba SL 29 Dual Air 80mm
    Shifters SRAM X.7
    Front Derailleur SRAM X.7 31.8, Low Clamp, Top Pull
    Rear Derailleur SRAM X.9
    Shifter Cable/Housing Alligator PTFE Slick Stainless
    Brake Levers Avid Elixir CR Hydraulic, Black
    Front Brake Avid Elixir CR, 160mm, 6 Bolt Stainless Steel Rotor
    Rear Brake Avid Elixir CR, 160mm, 6 Bolt Stainless Steel Rotor
    Brake Cable/Housing Avid Hydraulic
    Crankset Truvativ Stylo 3.3
    Bottom Bracket Integrated with Crankset
    Cassette Shimano CS-HG61-9 11-36T 9speed
    Chain SRAM PC-951
    Headset FSA 1-1/8" Orbit XL II Threadless
    Handlebar Sette XLR OS 31.8 Alloy, Black
    Grips Sette S-Type Grip, Black
    Stem Sette Edge OS, 10 Degree Rise, Black
    Saddle Sette Lynx
    Seatpost Sette APX Alloy, Black, 27.2 x 400mm
    Rims Mavic 719 Black, Disc Specific, 32H
    Front Hub Shimano Deore M529, Black, 32H, 6 Bolt Disc Mount
    Rear Hub Shimano Deore M529, Black, 32H, 6 Bolt Disc Mount
    Spokes 14G/15G Black Stainless Double Butted Spokes/Anodized Black Nipples
    Pedals Shimano PD - M505, Black
    Front Tire Kenda Small Block Eight DTC 29" x 2.1, 60 tpi (Folding Bead)
    Rear Tire Kenda Small Block Eight DTC 29" x 2.1, 60 tpi (Folding Bead)
    Color(s) Polished Aluminum
    Warranty 5 Years
    Weight 26 lbs / 11793.4g / 11.8kg (Medium Size Avg.)
    Motobecane 29 Pro SL
    Frame MOTO29X Aluminum with TrailTuned PowerStay Design, DualProfile Downtube with reinforced Gusset, replaceable rear derailleur hanger, water bottle mount
    Fork RockShox 29er Reba SL WITH Motion Control damping and PopLoc Adjust, 100mm travel*, Adjustable Rebound
    Crankset TruVativ FireX, 22/32/44T with integrated GXP BB
    175mm on 19 and larger / 170mm on 17 and smaller
    Bottom Bracket TruVativ GXP external bearing, 68mm
    Pedals Mountain Platform
    Front Derailleur Shimano Deore, 31.8mm clamp
    Rear Derailleur Shimano XTR long cage or Shimano XTR Shadow (no choice)
    Shifters Shimano XT 2-Way Release Rapid Fire 27 speed trigger shift
    Cassette/Freewheel Shimano HG cassette 9 speed 11-32T
    Chain Z9000 super narrow 9 speed
    Hubs Gravity by Formula Sealed Bearing Disc, Black Anodize finish with Quick Release
    Spokes Stainless steel
    Rims WTB Trail29 LaserDisc Black anodized Aluminum
    Tires Kenda Small Block8 29x2.1, Tomac Edition, Folding Bead
    Brakes Avid Elixir Hydraulic Disc front and rear, 185mm rotor
    Brake Levers Avid for Disc Brake
    Headset FSA or CaneCreek (NoChoice) Sealed Bearing threadless 1 1/8 in
    Handlebar Ritchey Comp Black Finish Aluminum 6061 T6
    Stem Ritchey Comp 31.8mm Black Finish Aluminum threadless
    Tape/Grip WTB DualCompound
    Saddle WTB RocketV
    Seat Post Ritchey Comp Black Finish Aluminum Mountain 27.2x300mm
    Seat Post Clamp Super Light Alloy with Quick Release
    Sizes 13", 15", 17", 19", 21" Click for 29R Geometry
    Access XCL 9.7
    BOTTOM BRACKET: TruVativ Giga X Pipe XR
    BRAKES: Avid Elixir 5 Hydraulic Disc w/ 185mm front, 160mm rear
    CASSETTE: SRAM PG-950, 11/34T, 9-speed
    CHAIN: KMC HG73 1/2" 11/128" 106L
    CRANKSET: TruVativ FireX 3.3 aluminum, 22/32/44T
    FORK: Rock Shox Tora SL 100mm travel
    FRAME: 6061 Aluminum
    FRONT DERAILLEUR: SRAM X.7, 34.9, top-pull
    GRIPS/TAPE: Velo Oury
    HANDLEBAR: MTB, butted aluminum, 710mm, 25mm rise
    HEADSET: Cane Creek Semi-integrated
    LEVERS: Avid Elixir 5 Hydraulic Disc
    PEDALS: Wellgo WPD-801, chromoly axle
    REAR DERAILLEUR: SRAM X.7, long cage
    SADDLE: Velo
    SEATPOST: 7075 Aluminum, 31.6, 350L
    SHIFTERS: SRAM X.7 Trigger
    STEM: Forged Alloy 4-bolt, 7 rise, EXT:15"=90mm,17"=100mm,19"=110mm, 21/23"=120mm, 31.8
    TIRES: Schwalbe Albert HS 29 x 2.1"
    WHEELSET: Rims: Mavic TN 719 Disc, 29", 32H; Hubs: CNC alloy, disc, sealed, 32H
    Does anybody see anything in the other bikes that would be a - or + comparred to the Sette's offerings?
    I received the Razzo frame as a Christmas Gift this past year. I built it up with parts I had and have upgraded some (mostly wheels). Don't have experience with the others. I would say that the Razzo will be the lightest of the three if that matters. You could drop weight from it just by switching out the wheels. Mine is below 26lbs and could be lighter with higher end parts.
