Page 2 of 11 FirstFirst 1 2 3 4 5 6 ... LastLast
Results 26 to 50 of 272
  1. #26
    Future Rainbow Jersey
    Reputation: ziggurat22's Avatar
    Quote Originally Posted by apacherider
    Yep. Niner's are one of the most overpriced frames around. Vassago is a close second. Pretty run of the mill frames. $250 is about right for frames of that quality.
    Vassago's not nearly as pricey as niner. $479 for a Bandersnatch, while considerably more than I remember them selling for, still isn't bad. It's a nice frame.
    "If I can't work to make it...I'll rob to take it..."
  2. #27
    Reputation: syl3's Avatar
    Quote Originally Posted by 29erPilot
    hybrid not mtb 29er
    would only consider it for offroad dropbar projects (monstercross, touring etc, if the tyre clearance is there)
  3. #28
    Quote Originally Posted by gthcarolina
    This 29er build kit shows up on the same page.
    http://www.pricepoint.com/detail.htm...&hprice=739.98
    That's a decent package, but the wheels...yikes! Nearly 2700 g. Can't expect too light at that price for all of that stuff.
  4. #29
    ballbuster
    Reputation: pimpbot's Avatar
    looks pretty nice
    Anyone know about these frames? Specs,geometry? Who makes them? Interesting looking frame for the money.
    http://www.pricepoint.com/detail/188...tail-Frame.htm
    I shoulda got that instead of the motobecane fantom 29er. My bike would have been a pound and a half lighter, and probably wouldn't have shaken my teeth out as much.
    I really like the polished alu.
    Also, isn't the Air9 scandium?
  5. #30
    Recovering couch patato
    Reputation: Cloxxki's Avatar
    That BeOne is a hybrid indeed. They called it an MTB but it's a fat tire hybrid. I would have gotten it if it had canti mounts. For a monstercrosser build.
  6. #31
    Harmonius Wrench
    Reputation: Guitar Ted's Avatar
    Quote Originally Posted by pimpbot
    Hmmmm...........not so much, most likely. This Sette is made from 7000 series Aluminum, which is stiffer and generally yeilds a stiffer ride. That, of course, may not apply here, but the chances are higher that it will ride stiff.
    More than likely ball burnished. It is a cheaper method of making aluminum look polished.
    Yes, but the comparison was to Niner's E.M.D.9, which is 7005 aluminum. The Sette frame is also 7005 Al.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
  7. #32
    mtb remember
    Reputation: southy's Avatar
    It looks to my eye like the latest generation Voodoo Aizan - similar welds, braces and stays - even the derailleur hanger bolts are in the same location. They probably just carried the Aizan's 7005 rear triangle to the rest of the frame and gave it a bent downtube. All speculation of course, but it looks pretty similar to me.
  8. #33
    Harmonius Wrench
    Quote Originally Posted by southy
    I thought it looked like a VooDoo as well, but it isn't identical, which would lead me to believe that it might be made in the same factory, but that is purely speculative. For all I know it could have been welded up anywhere by any factory.
    Doesn't really matter either.
    As an earlier poster stated, the questions need to be asked of Price Point, and then we may get the straight scoop. Until then, we're just a bunch of wankers that should be out riding.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
  9. #34
    I would love to be out riding.The only problem is I'm lacking my frame.I need to choose soon.My choices are
    On One $275
    Razzo $249
    KM $400ish
    Dambala $400ish
    I'm looking for a 24.5 TT 27.2 SP and the best fit for a 09 Reba set at 100mm I'm not changing it to 80 either.I'm going to running it 1x9I'm 240lbs.I would like to stay away from slotted and moving dropouts.I wanted to stay under 300.I've been scanning E-Bay and the Net.Recommendations welcome!
  10. #35
    Expert Crasher
    Reputation: GreenLightGo's Avatar
    24.5" TT = look at the Astrix Rook, size L. You can order one from Universal Cycles using the VIP code and it'll be roughly $365ish.
    Works great with a 100mm fork too.
    <table style="width:auto;"><tr><td><a href="http://picasaweb.google.com/lh/photo/dd-Wdlp8EYvin_82uNMCrQ?feat=embedwebsite"><img src="http://lh6.ggpht.com/_2W6rELw9q40/R2MZw1PHeuI/AAAAAAAABDU/zvSFZ-8RRYw/s800/IMG_2269.JPG" /></a></td></tr><tr><td style="font-family:arial,sans-serif; font-size:11px; text-align:right">From <a href="http://picasaweb.google.com/Kevin.Rants/AstrixRook?feat=embedwebsite">Astrix Rook</a></td></tr></table>
    Happiness depends more on the inward disposition of mind than on outward circumstances. Benjamin Franklin
  11. #36
    Universal doesn't have any.I do like this frame and would love to find one.
  12. #37
    Harmonius Wrench
    Some geometry info.......
    18 in eff tt 23.6. 20in 24.4in
    HA 71.5
    SA 74
    BB 68MM
    FORK 80 OR 100
    SEAT POST 27mm
    Numbers are direct from Price Point
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
  13. #38
    Expert Crasher
    Find an online retailer that does and see if they price-match. That's how I got my Karate Monkey for $50 cheaper.
  14. #39
    Reputation: b_rogowski's Avatar
    Hard to read, but the info is all there. An email from Pricepoint today.
    Razzo 29er
    Size (Seat Tube Length)
    Small (16"/41cm)
    Medium (18"/46cm)
    Large (20"/51cm)
    X-Large (22"/56cm)
    Effective Top Tube Length
    23.2"/59cm
    23.6"/60cm
    24.4"/62cm
    25.1"/64cm
    Actual Top Tube Length
    57cm
    58cm
    60cm
    62cm
    Stand Over Height
    75.3cm
    78.7cm
    82.5cm
    86.3cm
    Head Tube Length
    80mm
    90mm
    110mm
    130mm
    Head Tube Angle
    71.5 degrees
    71.5 degrees
    71.5 degrees
    71.5 degrees
    Seat Tube Angle
    74 degrees
    74 degrees
    74 degrees
    74 degrees
    Wheel Base
    108.1cm
    1082cm
    110.2cm
    112.1cm
    Chainstay Length
    45cm
    45cm
    45cm
    45cm
    Bottom Bracket Height
    12.8cm
    12.8cm
    12.8cm
    12.8cm
    Bottom Bracket Width
    68mm
    68mm
    68mm
    68mm
    Bottom Bracket Thread
    English
    English
    English
    English
    Seat Post Diameter
    27.2mm
    27.2mm
    27.2mm
    27.2mm
    Seat Clamp Diameter
    31.8mm
    31.8mm
    31.8mm
    31.8mm
    Front Derailleur Clamp Diameter
    31.8mm
    31.8mm
    31.8mm
    31.8mm
    Maximum Tire Width
    2.5"
    2.5"
    2.5"
    2.5"
    Recommended Fork Travel
    80mm-100mm
    80mm-100mm
    80mm-100mm
    80mm-100mm
  15. #40
    Thanks for the head-up guys.
    roccowt.
    rocnbikemeld
  16. #41
    New question here. bottom bracket height
    I hope the stated bottom bracket height is a type-o. 12.8cm would make it diffecult to pedal. maybe 12.8in?
  17. #42
    Map Maker
    Reputation: cbchess's Avatar
    I like that geometry - except the BB will have some pedals strikes.
    This looks like this years Zion frame (in that it is cheap). yum! Nice long top tubes.
    The price sure is nice. It would be even better if it was steel!
    Richmond, VA
    Ra-MORE mtb club
  18. #43
    luddite
    Reputation: MadCowRider's Avatar
    Quote Originally Posted by Guitar Ted
    Okay, it is definitely not a Niner! (courtesy pic for referance)
    I would venture to say that anybody with a design and the cash could get a Chinese manufacturing facility to make you as many of those Sette frames as you want. That's not far from the mark here, I'd wager. By the way, the Sette is shown sans rear derailluer hangar. I hope that is included at that bargain basement price.
    No hanger included.
    Email from PricePoint:
    Hello,
    They do not come with a derailleur hanger.
    Thanks,
    Manu
    800 774 2376
    Price Point Mail Order Ltd.
    E-mail: manu@pricepoint.com
  19. #44
    Team NFI
    Quote Originally Posted by cbchess
    I thought they stopped making Zion frames.
    If you hurt in your efforts and suffer painful dings. Then you are doing it right.
  20. #45
    Reputation: boomn's Avatar
    Quote Originally Posted by MadCowRider
    No hanger included.
    Hello,
    Thanks,
    Manu
    800 774 2376
    No derailleur hanger? I don't get it. I didn't think this was a singlespeed frame.
  21. #46
    I'm thinking of going with a monkey. I think it's my safest bet.I loved my old one,I know it fits,it has many options and the company has been around for a few years. What happenes 2 years down the road when I snap the thing in half? What kind of warranty do they have? It's hard to trust frames at my weight.I haven't heard of to many cracked Monkey frames. It doesn't look like you can fit a 2.5 either looking at the picture.
  22. #47
    Harmonius Wrench
    Quote Originally Posted by boomn
    The jist I got from them was that this frame is nearly at cost and that the hangar can not be included at that price.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
  23. #48
    Harmonius Wrench
    ........ It doesn't look like you can fit a 2.5 either looking at the picture.
    And the 68mm bottom braket shell width would also suggest that clearances may be tight on this frame.
    Riden' an Smilin'
    Guitar Ted
    Blog
    RidingGravel.com
  24. #49
    Help me understand this . What hanger do I need to buy? I have to buy a hanger to to get this frame going? Or do I just have to buy one as a replacement? Thanks
  25. #50
    Fat boy Mod Moderator
    Reputation: donalson's Avatar
    or buy this bike for about 200$ more... and get a reba SL, and avid juicy 7's ... but you'd prob need some other bits... but could sell the frame and recoupe some of your money...
    http://www.bikesdirect.com/products/...liff29team.htm
    just a thought...
    - Surly Disc trucker
    - '82 trek 560 roadie
