Results 1 to 36 of 36
    ~Reformed Mechanic~
    Reputation: Ace5high's Avatar
    Jan 2011
    Sette Razzo 29er
    Hey Guys, I might be building one for a buddy but cant seem to find a lot of feedback on the Razzo 29er.
    Anyone here riding one? and how are they compared to middle or top of the line 29er HT's?
    I do all my own stunts, but never intentionally...
    NedwannaB
    Reputation: JMac47's Avatar
    Nothin good in here?
    Quote Originally Posted by Ace5high View Post
    http://forums.mtbr.com/search.php?searchid=12316045
    Wait whuuut, who did he tell you that!?!?....
    ~Reformed Mechanic~
    Jan 2011
    Thanks, I do know how to use a search function. Most are first time 29ers and none address the comparison to higher end frames. God forbid anyone who owns one might actually want to provide some feedback in a new thread.
    Reputation: Joe V's Avatar
    Jan 2011
    Just got mine built last week and LOVE it, for the cost of the frame you can't beat it.
    ~Reformed Mechanic~
    Jan 2011
    Quote Originally Posted by Joe V View Post
    Wow that looks way better than the pictures Ive seen, nice lookin ride for sure
    Jan 2011
    Thanks Man,
    ~Reformed Mechanic~
    Jan 2011
    Thanks Man,
    Hey did you have this built for you? It appears that your RS fork is running 100mm or 120mm. One of my largest setbacks with recommending the built version is the 80mm travel that comes on both the 1.0 and 2.0 builds.
    Aug 2005
    Quick review of Razzo
    Ace, I picked up a Razzo 2.0 about 2 months ago and have about 15 hard rides in the rocky NE woods. I haven't had the chance to ride any other 29ers, let alone high end, but I do like it. So not exactly the review that you want, but here it comes (I've always ridden full susp - currently an 09 Enduro comp which I love).
    Flex. Was concerned, espec since I didn't have a thru axel in front. No problems up front, or in the rear.
    Vibration. Don't notice anything, but it is possible some nicer alum, steel or ti would feel great. Just yesterday riding I was thinking "damn, this thing feels great", so not changing.
    Fork. Extending the 80 mm to 100mm was 45 mins for a total idiot like me - very glad I did it. Very rocky here in CT.
    Bike is pretty hard on my butt, but taught me to get off of it a bit and pedal. I do like the cockpit, but did grab a shorter, higher rise stem (90 mm vs. 100mm, 18 deg rise) to address my back ache that I get on any long, hard ride on any bike.
    Only problem - running 2.2 Kenda Nevegals tended to touch my chainstays and started to wear away. Wrote Pricepoint, their response was that the nevegals are a bit wide, chainstay aluminum is thick, if I want to pursue a warranty and send it in they'll consider it. I'm not in love with the wear on my chainstays (cut past paint into aluminum about 1/2 mm??), but I don't think it is failing. I buzzed the outer 2mm of the tire's knobs with a bench grinder, no more contact.
    By the way, I have cleared rocky sections with the ht 29er that I was unable to on the Enduro, which I fancy a good technical climber.
    I don't jump anything over 1 foot on this, so no comment.
    Verdict: frame is light, solid, and offers no restrictions to me. The parts on the 2.0 were keepers. If you need 20 in or 22 in (18 in fit me perfect at 5 ft 10 in but is sold out), go for the built up 2.0 or 1.0 that are still in stock at great prices with the build. I'd love to ride a Ti or carbon frame, but wonder how that little bit of give would help out over 3 inch roots and rocks.
    That's all.
    ~Reformed Mechanic~
    Jan 2011
    Great response man thank you!
    You answered my biggest question. Apparently they ship with 100mm Reba's but they are just setup at 80mm of travel from pricepoint, just what I needed to know, awesome!
    NedwannaB
    No problem. Any time.
    Jan 2011
    No, I build all my bikes, The Reba is set at 100mm and is GREAT
    Jun 2012
    I just built one a day or so ago. I was not to sure about the 29er craze so I wanted to build something kind of cheap and not concerned about weight. Went with a Recon Gold 100mm up front. Came in at 27.3 pounds as pictured. I could probably get it below 25 pounds if I wanted. First ride on my local go to trail was great. Getting over the features with ease.
    CranksAroundtheCampfire
    The Razzo frame can take a lot of abuse! I raced mine all last season with a win in CAT 2 and yesterday made a strong outing at Endurorama at Allamuchy State Park in NJ. The frame rides smooth and will not disappoint. I believe its the best bargain for a aluminum 29er frame.
    I have done a few 2-3 foot drops onto flat ground with the Razzo 2.0. The Frame is still great, but I think I may have one or two small flat spots in my rear rim. I should probably stop doing that.
    It's not bad enough to need replacing, but if you like a perfectly smooth straight wheel it might get annoying.
    I weigh around 200 geared up if it matters. Also using the XL frame.
    My brother's 1st mountain bike
    I built this from some of my old parts from my 2011 Cannondale Flash, the crank, chain, handlebars, derail, and cassette. Everything else was bought from ebay using some great parts. Bike now has Thomson stem!!
    I was very impressed with this build, this bike is tight and very solid. The first thing I did was have the BB and headset Faced. It's worth the 50 bucks!! My brother is about 235lbs so Stans Flow rims with DT Swiss 340 hubs and Comp spokes. The wheel build was only 480.00 total. Set up tubeless. X Fusion fork for 260.00, Crane Creek headset 30.00, nobby nic 2.25 for 105.00 for both, Thomson stem and seatpost for 155.00 for both. Used Frame for 200.00.
    Avid Elixer 7 brakes for 134.00 new, and Shimano icetech rotors for 100.00. This brake setup works great by the way, the rear caliper just needed a little grinding to clear rotor. Seat bought used for 90.00. Hope skewers for 50.00, grips for 30.00, headset spacers 5.00.
    So around 1695.00 a great starter 29er that won't need any upgrades, he loves it!!!
    Trying to upload picts but no go!!
    NedwannaB
    Old parts?
    Quote Originally Posted by dgw7000 View Post
    Good thing they weren't circa 2009 like the ones I used on mine.
    Re your pix, are they sized down below the 197kb max to post on here?
    Oct 2012
    i like sette brand ^^
    Oct 2012
    i have Sette Serum Elite v2012
    Oct 2012
    i'm post my bike in Asia
    Dec 2011
    NedwannaB
    Upgrades
    Quote Originally Posted by JMac47 View Post
    9 cogs in back now!
    I have built two Sette's for two different friends that I ride with. I have had no issues with the quality of the frames. They are definitely one of the best bang for your buck mtb out there. I have also built and ride a Setter Razzo carbon 29er. I have not had any problems with the quality of that frame either. I did have a problem with my own diagnoses of a problem that I though I had. I just mark that up to Stupid on my part! LOL!
    My brothers bike that I built has been great, the frame is light and holding up great. Another great frame is Canfield Brothers Yelli Screamy 29er. $699.00 more weight but much stronger, slacker headtube and short chainstays. This should be a fun bike!!
    I just received my Sette Razzo X-7 (aluminum) a few days ago and my first impression is that I'm very impressed. I've been mtn biking since 1986 and have had x-c bikes, dirt jump, all-mountain and downhill bikes over the years. I bought the Razzo because I just got a condo in Orlando, Florida, and wanted to leave a bike here to have something to ride when in town. I live full time in the Lake Placid, NY area and do most of my mtn biking on the trails around Whiteface Mtn. Anyhow, I didn't want to spend a lot and was looking at the Airborne Goblin at $1200 and also the Orbea Alma M50 at $1400. I was going to go with the Orbea even though the Airborne had better components because I wanted to support the local bike shop near me. I'm sure I could have gotten the LBS down a few bucks but when I saw the sale Pricepoint was having I couldn't pass it up. (Last year I bought a Giant Defy Composite road bike from my LBS in Lake Placid - so I try to spread the wealth). The bike was $750 plus $60 bucks shipping. I'm 5' 9 1/2" and the 18" fit me perfectly. The bike took only 5 days to get from California to Florida. It was very well packaged and took maybe 15 minutes to assemble. I almost panicked when I went to install the front wheel and saw that a hub bushing was missing, but then I thought to check the plastic brake rotor protector that was snapped onto the hub for shipping, and sure enough it was stuck inside. Popped it off the plastic and into the hub and I was good to go. I just needed a slight adjustment on the rear der. cable, but otherwise everything was good. I've only had time to ride the bike around the neighborhood on paved roads but I like the way it feels. I can't wait to get the bike dirty once I find where the off-road trails are here in Orlando. I'll post updates and some photos once I get the bike dirty. I've been buying bike components from Pricepoint for several years but this is the first bike I bought from them and I'm very happy with the whole experience!
    Jun 2012
    Hey Ragman,
    Concerning riding in Orlando, there are 2-3 good local spots then a few more further out that are worth the drive. I will start with the obvious. Santos. Santos is the "mecca" of Florida riding, around 80 miles of trails in the system. They are maintained by the folks at omba.org if you don't ride anything else but this one you will be happy. It's about an hour to hour and a half from Orlando depending on where you are. It is worth the trip. The other further out one is Chuck Lennon. They have a facebook page. A lot of my friends describe it as a pump track on steroids. Lots of short quick elevation changes.
    Now for the more local trails. The three that come to mind are Snowhill/Little Big Econ, Soldier's Creek and Mt. Dora. Mt. Dora is a 2ish mile trail with lots of work being done by the folks at omba.org (again) to extend trails out. It is the only trail in the area that seems like it has any kind of "climbing" not really climbing but it has some extended slight elevation changes. Soldiers Creek is a short 1.3 mile trail. The locals do a 10 lap challenge. Do 10 laps under 1 hour and see who is fastest. Usually out on Wednesday nights. They've had some vandalism lately so check their facebook page to see if they are good to go. Lastly is Snowhill. I have a special place in my heart for Snowhill. It is the redheaded step sister that no one likes. I like it because it's close to where I live and its about 10 miles of trails so I don't have to spin around like a hamster like Mt Dora and Soldiers Creek. Message me if you want more info
    Thanks for the info droanx, I've done some online research and will probably check-out Santos very soon. I'm anxious to try out the Razzo in the dirt.
    Jun 2012
    There is a race the weekend of 4/20 and 4/21. It is at the "Landbridge" trailhead so you can either join in on the fun or go to the "Santos" trailhead and avoid the crowds. I plan on being at the race but I'm currently sitting in a hospital room with my wife so we'll see what happens.
    You will not be disappointed with Santos. Yellow=easy blue=intermediate and red=advanced. Have fun!
    I bought a small frame razzo 3 or 4 weeks ago and had the exact same thing Ragman had happen to him with his front hub bushing. I did the same thing....freaked out and couldn't figure out why my front wheel didn't fit. Then I looked in the black plastic hub protector and there was my bushing. Other than that I have been really pleased with the sette. I rode several demo bikes (Air 9, Felt carbon Hardtail,Specialized s-works Epic, Giant XTC carbon, Jamis ) and was ready to pull the trigger on the air nine but when the razzo went on sale last month I could not resist.So far the bike is great. Still getting used to it .( coming off a 26er specialized camber). Might just put me a set of Stans wheels on it and ride it a while.
    Picts my brothers 1st mtb bike, I built it with old and new parts. It rides really nice!! He loves it!!
    Jan 2011
    I bought a Sette Razzo 29er in 2010 for riding here in rocky, rooty Vermont. Can't beat the value of the components that come with the bike that's for sure. But I cracked two frames in the exact same place after one year of riding each frame-- on the top of the head tube right behind the headset. I am 160 pounds and don't do any jumping, so I find that odd that I was able to break a frame.
    Pricepoint was great about the warranty-- the sent me a new frame right away and gave me a $70 credit towards the first rebuild. After I broke the second one they gave me a credit for the price of a frame. I took the parts and put them on a Tall Boy.
    Reputation: Ksousa81's Avatar
    Trying to do a 2x9 32t/22t front derailleur what is the correct/cheapest derailleur to get the job done? the ones i have laying around the house don't seem to work for me...thanks!
    I still have the triple ring on my Razzo, but I might convert it to a 2x10 or maybe go with a 1x10. On another bike I have, a Transition Preston, I run it as a 2x9 with a SRAM x-7 and it works just fine. It's actually for a triple ring but I just adjusted the screw stop so the derailleur won't go past the 32T ring. I do use an x-9 shifter but if you want to save a few bucks the x-7 should be fine.
    Sette Razzo 29er
    Im trying to make the ride on my girlfriend razzo 29er a little more comfortable for her...
    She currently has a 29x2.0 in the front and a 29x1.9 in the rear is running 2.2s going to make things any more comfortable?? I don't want to use a suspension post just trying to take a little edge off... Any ideas that won't break the bank?
    Tubeless all the way !!!
    NedwannaB
    Quote Originally Posted by Ksousa81 View Post
    2.2's in Ikon, Wolverine, Conti's or Fast Track Controls running tube less would work. Add a CC Thudbuster and she just may out ride you!
    I put Geax Gato 2.3's on mine and it made a HUGE difference. See the thread I made on here about how 2.3's can (easily) fit on a Razzo.
