Results 1 to 8 of 8
    Qeustion about the Sette Riddik
    Hi,
    New here. I just got a used Sette Riddk. Trying to fine a manual but the maker says they have nothing. It seems to need a new crank. The one in it is a SR Sun-tour and the chainrings are riveted but the rivets are loose. And need to know how to tell what size the bike is. I'm 6" 300 lb dude. Would a rear shock with a coil spring be better them a air shock for my weight?
    Thank you for any help.
    Reputation: Aresab's Avatar
    You can put any crank in the bike, you need to see what bottom bracket is installed. I believe the Riddik was a frame only, rather than a whole bike. The Bottom bracket is a 68mm wide, and on mine, 113 mm spindle. I have ISIS cranks on mine.
    I saved off the spec's to a PDF, here they are:
    Attached Files Attached Files
    Thank you for your reply.
    Quote Originally Posted by RSabarese
    You can put any crank in the bike, you need to see what bottom bracket is installed. I believe the Riddik was aframe only, rather than a whole bike. The Bottom bracket is a 68mm wide, and on mine, 113 mm spindle. I have ISIS cranks on mine.
    I saved of the spec's to a PDF, here they are:
    How do you know what size frame I have?
    Cuánto pesa?
    Reputation: Jake Pay's Avatar
    The bottom bracket is the same size on all Riddik framesets...
    It's no magic trick
    Thanks but that's not what I was talking about. I was talking about bike size. The Riddik comes in 2 sizes. 17" and 19". I like to know which one I have.
    Quote Originally Posted by Jake Pay
    It's no magic trick
    Cuánto pesa?
    Quote Originally Posted by chuck732
    Measure from the center of the bottom bracket to the top of the seat tube...
    Thank you. I just did that and it's the smaller one 17". It small for me I'm 6'. But will have to do.
