Results 1 to 2 of 2
    Reputation: Dragos's Avatar
    Looking to buy the Sette Ace frame but need some help please!
    Hello,
    I'm looking to purchase the Sette Ace XC Frame W/Rockshox Monarch 3.3 ( http://www.pricepoint.com/detail/184...onarch-3.3.htm ) but I am not sure if all the parts on my current hardtail bike would transfer ok to this frame.
    Is there anyone that can tell me if i need to purchase something else and what in order to use the frame?
    Here are the specs of my current bike. Hope this helps as i am looking to make my purchase as soon as today
    Frame Kinesis X6Series Aluminum 3.2lbs Nominal weight, replaceable rear derailleur hanger, 2x H2O bosses
    Fork RockShox DART 3 WITH ADJUSTABLE REBOUND (120MM) AND LOCKOUT
    Crankset FSA DYNA-DRIVE 22/32/44T with Powerdrive
    Bottom Bracket FSA PowerDrive Axle Sealed bearing
    Pedals FREE Gravity DualStage Clipless/Platform
    Front Derailleur Shimano Deore
    Rear Derailleur Shimano LX long cage
    Shifters Shimano Deore Rapid Fire 27 speed trigger shift
    Cassette/Freewheel Shimano HG cassette 9 speed 11-32T
    Chain Z9000 super narrow 9 speed
    Hubs Gravity Disc Sealed Bearings with Quick Release
    Spokes Double Butted Stainless steel
    Rims WTB SpeedDisc Double Wall Aluminum
    Tires/ Tubes Panaracer FireXC PRO 26x2.1 / Presta Valve
    Brakes Avid BallBearing Mechanical Disc front and rear, 160mm rotor
    Brake Levers Avid FR5 for Disc Brake
    Headset Ritchey Sealed Bearing threadless 1 1/8 inch
    Handlebar Ritchey Rizer SC Butted Aluminum 6061 T6
    Stem Ritchey Comp Aluminum threadless
    Tape/Grip WTB DualCompound
    Saddle WTB SpeedV
    Seat Post Ritchey Comp Mountain 27.2mm Aluminum
    Seat Post Clamp Super Light Aluminum
    This is the link to the bike if you need anything else.
    http://www.bikesdirect.com/products/...om_trail08.htm
    Looking forward to your answer!
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    http://www.pricepoint.com/detail.htm...d=275%20USESA1
    for going to need a new seatpost, this shim will make yours fit you need 27.2-31.6 or just buy a new post thats 31.6.
    also check the diameter of the tube the front dérailleur clamps to it needs to be 34.9mm
    RAH!
