Results 1 to 12 of 12
    Fork for a flite
    I'm thinking of getting the flite as an all around bike. I normally just trail ride, where a hardtail is sufficient, but I also want to get a bike that I can take to a park to DH/Fr (higland mtb park). The stock bike looks like it would be fine for the lift accessed riding, but I don't know about the climbing. I was thinking of replacing the fork (a domain 318 coil 160mm of travel) for a lighter and/ or more adjustable one (maybe a fox 36 like the tallas? or just the domain 318 u-turn). Getting a fox 32 with 150mm of travel (again maybe the tallas) would save a lot of weight, and I think it would have enough travel for the lift accessed stuff (I rode at highland with a trek scratch 9 which had 160mm of travel, and it was great), but are the 32mm uppers sturdy enough? Also can you get converters so the 15mm QR axle will work in a 20mm hub? Any thoughts would be greatly apreciated. Any other fork recomendations?
    Last edited by cant think of a name; 07-15-2010 at 11:18 AM. Reason: mis-spelt the name
    Keep the Domain and simply convert it to a u-turn.
    Here are detailed instructions:
    Rockshox Domain 318 U-turn Conversion Instructions
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    RAH!
    Quote Originally Posted by facelessfools
    Only 140mm travel. The Flite works best 150-160mm. That's why I like the u-turn on mine.
    Quote Originally Posted by Dictatorsaurus
    wouldn't it be cheaper to just sell the domain it comes with (without using it) and then buy the u-turn version?
    Also would a bike this weight (if it had the adjustability of a u-turn) work for trail riding?
    It would cost you about $50 in parts for the u-turn conversion. So no, it is not cheaper to sell your fork and buy a new u-turn fork.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    OP, Dictator-totasaurus has got the right idea IMO
    and EDIT THE TITLE!!
    It's a F-L-I-T-E
    Honestly... ahh I give up
    steer tube length
    Does anyone know how long of a steer tube you would need on a fork for the flight? the head tube length is 4.72 in (120mm), but how much longer does the steer tube have to be? Would 7 5/8" be long enough?
    ~Disc~Golf~
    I can measure my minimum stack if you want
    that would be great, thanks! I found a good deal on a used 36 talas, but i want to make sure it will work.
    ~Disc~Golf~
    OK, I came up with a minimum Steerer length @ 175mm (with a CC ZS-110 and 40mm stem)
    Maybe Talal can measure his to confirm.
    I had a fox van 32 for a while then swapped it for a 36 van. The 36 is heavier but so much better in every way. It is a little harder to climb steep sections with the 36 but it's not that bad.
    Orbea Oiz
    Sette Flite
    Bianchi 26er ss
