Results 1 to 13 of 13
Thread: Flite Weight
    Flite Weight
    The medium Flite bike with the pedals is rated at 34.8lbs on the Sette website.
    I have a large frame and I weighed my bike on the bathroom scale and it came to 30lbs (+/- 2lb)
    The bike is stock aside from the following:
    - Maxxis Ultralight tubes. 125g/Each
    - Sette Type S grips
    - Sette Nyx saddle. 190g
    - Time Alium Clipless pedals
    - Shortened brake hoses and shifter cable housings
    Not bad at all considering how heavy the Domain fork is.
    Share your Flite's weight with us.
    "They Call Me Bone'z"
    Reputation: facelessfools's Avatar
    my nyx saddle weighed 201g.
    RAH!
    Reputation: Dremer03's Avatar
    sounds like a really good weight to me. Is your bathroom scale digital? Should be fairly accurate, if it is. It is more accurate to weigh yourself and them weigh yourself holding your bike. The difference it what your bike weighs.
    Big Foot Blue KHS XC704r
    Quote Originally Posted by Dremer03
    Analog. I believe it is pretty accurate. I weighed myself using the old school scale at my gym then weighed myself after I got home and it gave the exact same reading.
    I'm pretty sure my hardtail is around 30lbs and it gave the same reading.
    I'm guessing it will lose more weight when I switch to 2x9 and remove the big ring.
    ~Disc~Golf~
    Reputation: highdelll's Avatar
    yeah, weigh yourself.
    then weigh yourself holding the bike.
    much more accurate.
    ~mine is just under 34lbs according to the LBS scale and 34 on the nose using the above method
    I did the 'weigh by itself' method before and got screwey #'s before - I don't think a bath scale is accurate at such "low" weights
    Honestly... ahh I give up
    Weight without bike: 186lb
    Weight with bike: 219
    Bike weight: 33lb which seems more reasonable.
    Quote Originally Posted by Dictatorsaurus
    Still pretty good since they say it ways almost 35 on a medium frame and yours is 33 on a large
    In terms of feel I don't really notice a difference in weight between the Flite and my hardtail. Then again I don't have a scale implanted in my brain. I'm sure Highdelll has one in his though. He's too smart and "balanced".
    I'm going to switch out the rear 2.35 Nevegal. I'm considering the Syncros Point N Chute 2.35 which weighs less and is supposed to roll better.
    The Nevegal has great traction, but feels like you're rolling through thick honey all the time. Very nobby and slow.
    ~Disc~Golf~
    ...I'm sure Highdelll has one in his though. He's too smart and "balanced".
    hay, that's a little too close to Fox's slogan...
    http://www.pricepoint.com/detail/187...2.20-_-2.4.htm
    weight weenie approved
    i haven't owned them.
    i have hutchinson python/ piranha
    RAH!
    Quote Originally Posted by facelessfools
    Recommended inflation is 50-65 psi. Thats pretty high.
    ~Disc~Golf~
    you read instructions?
    we're Flite owners for god sakes! we don't care 'bout no destruktshuns!!
    Reputation: Dr Wankel's Avatar
    Oct 2007
    My small is coming in at 31lbs. on the bathroom scale.
