Results 1 to 16 of 16
    Steve OH
    Flite chain issues
    i recently purchased a sette flite , got it all put together and cant get the chainline set very well its trrowing my FD off pretty bad , has anyone else had this issue and if so what was the cure , i even took it to my LBS and he seemed to be stumped , ill try to get some pics a little later
    Quote Originally Posted by firemechanic07
    I ran the 3x9 setup when I got the Flite and had no issues switching between all 3 chainrings.
    Do yourself a favor and dump the big chain ring and install a BBG Bashguard. You will never look back. 2x9 for the Flite is the perfect setup.
    Steve OH
    for some reason nothing will line up , im pretty sure i have a 3x8 setup , i basically cannableized my haro flightline to assemble this frame, the mech at my LBS said really the only way to line it up would be to trim my bottom bracket housing , im not to crazy about basically grinding my bottom bracket housing away , im new to mtn bikes , so im not up on all the terms yet , im not sure what a "bbg bashguard " is also this is a stupid question but which hole in the rockers is for the 6" travel , the rear isnt it ?
    The hole closest to the seat tube is 6".
    BBGbashguard.com. It replaced the big ring with a guard that protects your second chainring.
    Steve OH
    Quote Originally Posted by Dictatorsaurus
    would i need to increase my second chainring size ? and currently my chain is hanging up going to the smallest one , what is the purpose of the chain guide ?
    Steve OH
    heres a pic of the FD
    Steve OH
    is there any hope for the odd cable angle ?
    Reputation: Dremer03's Avatar
    I am pretty certain you have the wrong style front derailleur for the frame. You need a Low Clamp, Top Pull Front Derailleur. What you have on your bike is a High Clamp, Top Pull.
    I am also pretty certain the angle of the cable is pretty normal for the Flite.
    Big Foot Blue KHS XC704r
    Steve OH
    i had a low clamp , that i tried originally but i couldnt get it to sit low enough not to hit the chain when on the small chain ring is the solution to bend it ?? i work on heavy equipment and trucks for a living and get a bigger hammer works well for them , im not so sure how that would work for my mtb
    AZ
    AZ is offline
    Reputation: AZ's Avatar
    Are the spacers in your bottom bracket installed correctly ? If they are not your chain line will be screwed .
    Steve OH
    i actually do not have any spacers in there , it needs to move in farther closer to the shell , well thats what the mech at the lbs told me , his solution was to grind away at the shell *scary stuff*
    AZ
    AZ is offline
    Do you have a square taper bottom bracket ? If so , a shorter spindle to correct the chain line is the proper fix .
    Steve OH
    i think it might be my crank , its just a cheesy suntour low budget crank , i just ordered a new one by raceface hopefully that will help
    AZ
    AZ is offline
    Yep , pretty easy to setup , just put the spacer/spacers in the right place . Good luck .
    Steve OH
    got my new cranks today , race face evolve DH from wheelworld , im a little dissapoiunted that they sent me a previously enjoyed bottom bracket, but its installed , chainline is dead on , got my lowclamp FD to work it shifts nice , now ive got a 2X8 with a bashring , i need to switch to a 9 thanx to everyone for the advice
    AZ
    AZ is offline
    Congrats , enjoy .
