Results 1 to 6 of 6
    2013 Fox 34 160mm A-C Height?
    Anyone know what the A-C height of the new 34mm fox float would be for the 160mm??? I see the 32 's @ 150mm is 520 and the 36 @160mm is 545.
    Guesing 545 to allow more room for the 650B option?
    Interested to know as well...
    Jan 2005
    I cannot imagine the AtC height would change. Just the larger stanchions.
    Not just famous; infamous
    Reputation: coolhandluchs's Avatar
    From the 2013 Fox Forks post:
    "The 34 platform has been extended to the 26 and 650B wheel sizes, ... The 34 is 20% stiffer than a 32, and approximately 200 grams lighter than a comparable 36, and they designed in an axle-to-crown that is 7.4 mm shorter than its 36 brethren."
    Granted, that's probably comparing the 26" versions, but at least it gives ~538mm as a starting point.
    Edit: Just saw a report on the upcoming RS Revelation which has an 11mm A/C difference between the 26" and 650 versions.
    "If youíre wondering, the axle to crown for a 150mm Revelation fork is:
    - 558mm for 29er
    - 539mm for 650b
    - 528mm for 26"
    Thanks for the heads up
    Reputation: haze0105's Avatar
    Thanks for the info, very helpful.
