Results 1 to 3 of 3
    What XTR Front Der. compatible with Spark 2013 ?!
    Hello guys,
    i have a problem here and i need help to solve it.
    My frame is a Scott Spark 900 RC 2013. And i am using a Shimano XTR Double M980 Crankset 38-26T.
    I am looking for a XTR Front Der. to use with my system (that is all xtr)BUt...
    -The XTR M980 Front Deraileur is only for Triple Cranksets;
    -The XTR M985-E is for use with 40-44T cranks;
    -The XTR M-985-E2 is compatible with my 38T crankset. But it is not compatible with the Spark frame.
    Any suggestions ?
    Is it impossible to use a 38-26T system and a complete XTR kit with a Spark frame ?
    Thanks,
    Eimart
    Just discovered that there is one version FD-M986-D (Direct Mount) , that you fix it to the frame with 1 bolt.
    I dont know if the Spark 900 RC 2013 Frame i have to use the E2-Type (that uses 2 bolts to fix it to the frame) or the M986D (that uses 1 bolt).
    Anyone can help me here ?
    Scott Support told me that i need a "Shimano XTR M985 E2-type 2x10" .
    , directly mounted on the frame.
    Thanks all,
    Problem solved
  1. Help Cutting fat Scott Spark RC 2013
    By eimart in forum Weight Weenies
    Last Post: 04-30-2013, 05:10 PM
  2. Spark 2013 and Xtr Incompatibility
    By eimart in forum Drivetrain - shifters, derailleurs, cranks
    Last Post: 04-25-2013, 05:36 PM
  3. 2013 Spark 900 with Fox Float CTD Remote?
    By CyclingJunkie in forum Scott Sports
    Last Post: 04-19-2013, 07:10 AM
  4. Scott Spark 910 v. Kona Hei Hei Supreme (2013)
    By cbeach in forum 29er Bikes
    Last Post: 02-22-2013, 05:33 AM
  5. Replies: 3
    Last Post: 11-20-2012, 09:54 AM
