Results 1 to 2 of 2
    Jun 2016
    New question here. Twinloc Scott Article number: 216350 & 216351
    I looking for a new twinloc for equalizer 2. Are these 2 twinloc levers the same? Scott Article number: 216350 says it's for the Equalizer 2 and Scott Article number: 216351 used for Nude TC/Nude 2 Rear Shock. From the pictures these 2 levers look very much alike.
    Nude Tc/nude 2 rear
    equalizer 2 lever
    Does anyone know if Article number: 216351 can be used with the equalizer 2 rear shock?
    Reputation: Twinky's Avatar
    Jul 2015
    well it depends on what year and model you own.
    the equalizer is the old pull shock on the genius.
    and the nude is the new push shock on the genius 2014 and up FOX (2013 DT)
    so if you own a 2014 and up model you need the Nude version (216351)
    if you own a 2013 model you need the DT version (216352)
    if you own a older model look at you rear shock and order the twinlock with the same number on the equalizer shock.
  1. Replies: 6
    Last Post: 04-26-2016, 02:18 PM
  2. Possible to remove Scott Twinloc lever System?
    By Cam. in forum Shocks and Suspension
    Last Post: 02-15-2016, 11:40 PM
  3. Scott Spark 60 2012 - twinloc issue
    By lukas718 in forum Scott Sports
    Last Post: 09-08-2015, 07:39 AM
  4. Scott Spark 60 2012 - twinloc issue
    Last Post: 09-07-2015, 07:56 PM
  5. Scott Twinloc lever
    By K-Sucio in forum General Discussion
    Last Post: 02-06-2012, 09:07 PM
