Page 2 of 5 FirstFirst 12345 LastLast
Results 101 to 200 of 467
  1. #101
    Reputation: Sonny's Avatar
    Hi Gezzza,
    Would you mind tell me how many layers of yellow tape stick on the carbon rim ?
    I have the same rims / tires combo and would like to convert it to tubeless.
    How many psi you pump up the tires ?
    Jun 2010
    Hi All,
    I would like to find out, is it correct to use a 100mm Fork on the Spark 50 2010?
    I understand the stock bike comes with a 120mm fork, however I intend to get the frame only and transfer my 100mm from my current bike.
    Thanks in advance.
  3. #103
    Jun 2010
    I think 120mm is too much for a XC bike. My Spark (small) came with 80mm set Reba. Very good to uphill and enough travel for my use. Now I use a 100mm Sid.
  4. #104
    Quote Originally Posted by RideFaster
    Move Those Qr Levers!!!!
    Why?
    they are ratchets so they cant be fliped open
  5. #105
    Quote Originally Posted by Sonny
    Hi Gezzza,
    one layer of yellow tape and the Olympic valve needs some silicon to seal it.
    and you need CO2 or compressor to get them to work
    i run 28 psi front and rear
  6. #106
    Quote Originally Posted by Gezzza
    Thanks Gezzza !
    Silicon on tire beam ??
  7. #107
    Thanks Gezzza !
    On the olympic valve as the profile of the rim is differant to the valve, you cant get it to seal with out a tiny amount.
  8. #108
    Spark 10 / DT XRC 1250 / SRAM XX
    Here is my Large 2007 Spark 10. Virtually all parts are new for the 2010 season and complete weight is 20.78 lbs.
    Part highlights are:
    2007 Scott Spark 10 frame (Large)
    Fox 32 Series F100RLC FIT fork
    DT Swiss XRC 1250 wheelset
    S-Works Fast Trak LK 2Bliss tires 2.0" (Set up w/ Stans yellow tape, Olympic valves, & sealant)
    SRAM XX drivetrain and brakes (Q166 26/39 crankset, 185 mm front/160 mm rear rotors, 11-36 cassette)
    Ritchey WCS: headset, 4-axis carbon matrix stem, carbon low rizer bar, foam grips, carbon seatpost, marathon saddle
    Eggbeater 4Ti pedals
    Alligator i-Link shift cables/housing
    Arundel bottle cage
    Garmin Edge 500 computer
  9. #109
    Here´s my custom built 2009 Spark 10. I just bought the frame new and more or less moved over all the kit from my Scale. Nothing special about it really.
    XTR drivetrain and pedals, Fox 32 F100RLC, Thomson Elite X4 stem, Mavic Crossmax ST wheelset, Avid Juicy Ultimate brakes, Schwalbe Racing Ralph 2.25 tires. Weighs in at 10,45kg.
    My philosophy is "not too heavy, but not too light and fragile either!". Very satisfied with it so far. Lighter and more agile than anticipated.
  10. #110
    Quote Originally Posted by E46_M3
    Arundel bottle cage
    Very nice spark! Anyone know where I can find that ritche wcs headset?
  11. #111
    My Spark 60 2009, in its natural element.
    Any suggestions to lower the weight would be nice.
    Blueliner
  12. #112
    Try again with the picture this time
    Attached Thumbnails Attached Thumbnails Sparks...lets see em-picture-332.jpg
  13. #113
    Nov 2008
    Quote Originally Posted by Blueliner
    Blueliner
    It generally comes down to "How much do you want to spend, i.e., what's it worth to you?"
    If that's your property where the picture was taken, you might want to sell an acre (hectare) or two (if the real estate market has yet to completely melt down in your neighborhood). With the proceeds, first purchase a Spark HMX frame (while the distribution routes are still flowing), then head over to weight weenies and choose the components that suit your fancy (ebay's and paypal's fee's are still tolerable) and spend the balance of those "proceeds" there. However, I suggest you sell half your property and buy gold, silver and the appropriate tools for growing food on the other half of the property. Keep your "60" and stock up on extra components for it, i.e. tires, tubes, etc.
    You might want to do this all before the global fiat currencies tank between now and the first quarter of 2011.
  14. #114
    [QUOTE=timbuktu]It generally comes down to "How much do you want to spend, i.e., what's it worth to you?"
    You might want to do this all before the global fiat currencies tank between now and the first quarter of 2011.[/QUOTE
    I new I should have went with a Giant
  15. #115
    LOL Brilliant!
    But responding your question. First of all pay attention to wheels. If you want to invest buy lightweight wheelset + nice and light tires + inner tubes OR install not (!) tubless tires on tubless rims with a speciall sealant.
    Low rotating mass makes big difference.
    After that need to sell some hectares… and invest in seatpost/handlebar/stem/crankset etc… good luck!
  16. #116
    Here's my custom built Spark 09 LTD
  17. #117
    Reputation: jasper9's Avatar
    Jan 2009
    Stock 2010 Spark 35 picked up on year end close out. Replaced Saddle and grips only so far. 0 miles on it so far
    --- jasper9 ---
    T: @jasper9
    W: http://www.jtri.com
  18. #118
    The Cheater
    Reputation: Veda's Avatar
    Dec 2009
    Quote Originally Posted by Fast1
    What specifically do you feel the Racer-X does that is superior to the Spark?
    I currently have both a 2010 Spark 30 (frame only with all upgraded parts except stock Reba fork) and also a custom Titus X 2009 with RP23 Boost Valve and Fox RLC fork. Both are weighted exactly the same. Just today I disassembled my Spark for sale. Why? Because of 1 thing only, when the twin-lock is open in any of the 2 positions it bobs even on smooth pavement. Granted there is also a problem of excessive compression at the fork during hard front braking but I can live with that. Pedal bob is unacceptable for a bike costing so much. On the Titus even without pro-pedal on I can pedal as hard as I want on the road and it won't bob a bit. And oh I tried everything and the bob won't go away. I've actually managed to get 5 of my friends to buy Sparks of different models and they all exhibit the same bobbing issue. Someone said it's a problem with the frame design and that it's too much for the rear shock to bear everything. Who knows... all I know is Sparks do BOB. And it doesn't matter if it has one of the lightest frames in the world... the Titus (and probably a Santa Cruz or DWLink bike) is way faster on climbs, has better balanced seat tube angle, more stable on descents.
    Which gets back at my issue right now of searching for a frame lighter than the Titus X, the Blur XC or the ASR or the upcoming 100mm travel Ibis?
  19. #119
    Quote Originally Posted by Veda
    I have a LTD spark with dt nude shock and I never have had a problem like you.
    Bobbing is soo light, I tried different bikes like cannondale rz, specialized epic and for me spark is the best. I set adeguate pressure into the shock and fork (a dt xrc) and when I put the traction control mode I pedal in the climb without energy loss and and exceptional grip
  20. #120
    The Cheater
    Dec 2009
    Quote Originally Posted by darioras
    Compared to those bikes, yes the Spark is still superior but with newer more modern suspension designs that got rid of bob without having to fiddle with lockout levers... it's outdated. But you have to agree that it still bobs a little regardless unless completely in locked position...
  21. #121
    Nov 2008
    Got 2 Sparks (HMX). One for training and one strictly for racing (18.5lbs.). Have yet to lose a race in two years. I'd say, proof is in the pudding.
    I think you got "BOB" on the brain. LOL.
    I'd say you need to get out of your brain and into your body.
    In regards to the "Titus is way faster on climbs", more LOL.
    Hey, any time, anywhere. Well, almost anywhere. How about this next summer in the Pacific NW? I've got a 4000' climb outside my backdoor. I was going to say "pink slip for pink slip?" but to be perfectly honest, I have absolutely no interest in your Titus.
  22. #122
    The Cheater
    Dec 2009
    Quote Originally Posted by timbuktu
    I think you got "BOB" on the brain. LOL. I'd say you need to get out of your brain and into your body. In regards to the "Titus is way faster on climbs", more LOL. Hey, any time, anywhere. Well, almost anywhere. How about this next summer in the Pacific NW? I've got a 4000' climb outside my backdoor. I was going to say "pink slip for pink slip?" but to be perfectly honest, I have absolutely no interest in your Titus.
    LOL. No need to get all sensitive and cocky when your bike is deemed to be worse than another's and go ranting on who's the faster superior cyclist since it's not part of the discussion. I'm only trying to prove a point about a particular bike in this case being the Spark which I own. Though I'm inclined to believe that if you actually use a Titus X you'd win those races faster. As for the bobbing it's not all in my head or what I felt when pedaling since I can actually see the shock moving by 1cm with every pedal. If you read my other posts, I've mentioned that we've got 9 Spark owners of different models in our group with most are selling it due to the bobbing. But if it's sufficient in your area to get you to the podium and you have no interest in learning how to improve your ride then hey more power to ya...
    How bout you come over to my place... let's see halfway around the world to Rotorua? Or Tasmania?
  23. #123
    Reputation: Rodent Snapper's Avatar
    Veda,
    I've seen you posting here and at Star Bikes WW site on this topic. You are crazy to sell your Spark without buying a used RP23 off ebay or such. I have a 2007 Racer X alloy and a 2010 Exo-grid X. The Spark can hold its own. The last upgrade I did to my Spark was the RP23 and I wished it was the first.
    pimp of the year
  24. #124
    Have anyone got there 2011 spark yet?
  25. #125
    Dec 2009
    Nice Sparks :)
    Here is my sparkie,
    It's based on 2010 Spark Ltd, listed below Some of the new components:
    THM Clavicula MTB
    XX RD
    XX FD
    XX Triggers
    Cassette: 11-36XX
    Chain Rings: Carbon Ti 42/26
    MCFK Seat Post
    Tune Saddle speedneedle Alkantara
    Smudek Seat post Clamp
    QR Tune 16/17
    I've Changed to Formula 2P 160 Rotor
    Formula R1 Mixmaster
    I-Links cables
    Extralite cyberends
    8.700 kg / 19.180 pounds (include 4Ti Pedals)
    Cheers,
    Adi.
  26. #126
    The Cheater
    Dec 2009
    Quote Originally Posted by Rodent Snapper
    Veda,
    Sold the frame + rear shock + fork for only 50% and the condition was new too. Sad to say that it isn't easy to have the RP23 shipped to where I'm at. Was able to get mine as light as a Scale 10 2011... The Titus X is a temporary solution, until my SC Blur XC arrives.
    Attached Thumbnails Attached Thumbnails Sparks...lets see em-custom-spark-30.jpg
  27. #127
    Dec 2008
    Finally got my Spark RC done. Hubs had been on back order since Febuary. 18.45 lbs.
    Attached Thumbnails Attached Thumbnails Sparks...lets see em-img_1194_1_1.jpg
  28. #128
    Quote Originally Posted by xc71 View Post
    Very nice!
  29. #129
    Dec 2008
    2011 Spark 50
    My 2011 Spark 50 chillin at the beach.
  31. #131
    Reputation: iamspartacus's Avatar
    May 2012
    What, no more Sparks??? I pick mine up in a week or so!!! Come on Scott fans, show us more!!!!
  32. #132
    My Spark 29 Expert at Tsali.
  33. #133
    May 2012
    Sweet ride aenima. Now lets get more of our bro's rides up here!!!!
  34. #134
    I'll play.
    2010 Scott Spark 20 frame
    FOX F120 RLC FIT
    XTR drivetrain
    Industry 9 Ultralite with Rocket Ron / Racing Ralph
  35. #135
    Reputation: pablobaq's Avatar
    here is mine... love this bike!
    By pablobaq at 2012-01-30
  36. #136
    May 2012
    pablobag, very nice photos. Way to keep the Spark thread alive. I can't wait to get photos up on mine soon (probably in about a week when I pick it up)!!!!
  37. #137
    Reputation: txxcrider's Avatar
    Aug 2010
    Here's mineSparks...lets see em-imageuploadedbytapatalk1339779303.691982.jpg
  38. #138
    May 2012
    txxcrider, that is another fine example of sweet Scott engineering. I can't wait for mine to show up next week. I am assuming from your signature that you are from the Lone Star state? I used to live there, but don't miss the summer heat.....or hail storms!!!!!!
  39. #139
    Aug 2010
    Correctamundo, ATX and the 2013's will be here soon....
  40. #140
    May 2012
    My bike is in!!!!! I should pick it up Wednesday night!!!!! Pictures, as promised, to follow........but keep all your Sparks up here now!!!!!!
  41. #141
    May 2012
    After some confusion yesterday, I WILL get my Spark today!!!!! Can't wiat......it looks good!!!!!!
  42. #142
    May 2012
    After a long wait, here it is.............
  43. #143
    Sweet!
    Love the color!
    Enjoy getting it dirty!
  44. #144
    May 2012
    Thank you so much. The color was one of the deciding factors. I rode a bunch of bikes that rode great, so it came down to color and cost. This won on all counts!!!! Tomorrow morning will be its maiden voyage in dirt!!!!!!
  45. #145
    Iamspartacus,
    Do you have twin lock?
  46. #146
    Iamspartacus,are you in Ocala?
    I noticed your bike is from Brick City, and your profile says you are in Central Florida.
  47. #147
    May 2012
    pablobaq, no, this model does not have the twinlock. Although, it does have the cable routing tie downs to add it later. I am not that skilled of a rider yet to know if this was a good or bad choice. Regardless, I got the bike for a great deal, so no worries.
  48. #148
    May 2012
    aenima, yes, I am in Ocala. You a central florida rider too???
  49. #149
    Jun 2010
    Finally snapped a pic of mine.
  50. #150
    May 2012
    rlucky82, very nice ride. Is there anything sweeter then that matte black base coat on those Scott's........amongst so many other awesome things about these bikes????
  51. #151
    Iamspartacus, I live in Ocala,and ride several times a week.
  52. #152
    May 2012
    aenima, if you don't mind hanging with a noob on the trails, I would love to meet up and ride one day.
  53. #153
    Jun 2010
    I actually like the gloss (old school) but I am living with it :-D
  54. #154
    Big Boy
    Reputation: texasnavy05's Avatar
    Quote Originally Posted by txxcrider View Post
    Here's mineClick image for larger version.
    How are you liking those rubena scylla tires? thinking about grabbing some, cause the ikons are so expensive. got a weight on them?
    -It's time to shred some mild to moderate gnar!!
  55. #155
    Reputation: jvm051's Avatar
    Here is my Spark, a 2011 Spark 40. Just a few upgrades, with a shorter 3T ARX Team stem, KCNC handlebar, Specialized grips and saddle, cut the seatpost down to 350mm, and the switch from the XT triple crankset, to the 1x10 setup running a 32t front ring. I also have a picture next to my Scott CR1 Road Bike. I love Scott bikes, and they are not as common to see as the other big names.
  56. #156
    Great!
  57. #157
    May 2012
    Its nice seeing these Sparks out there!!!! Keep em coming!!!!!
  58. #158
    Jun 2010
    I have a question to whom had experienced both new and old Spark frames.
    I have a 2008 carbon Spark and love the bike. Quick, light, high quality frame.
    Looking to the new model geometry, considering the seat tube angle, bike looks more "trail oriented" than the older "xc racer" model.
    Is it true?
  59. #159
    my new 29er RC
    This is my new 29er 2012 spark RC
    Cut the handle bar, 2cm at each side
    Swaps: seatpost: KCNK Ti Pro 8000 350 mm, Saddle: Selle San Marco Aspide Carbon rails, grips: 40g KCNC foam, rear tire: Scwalbe racing Ralph 2.1
    Total weight (size L, incl. sealant) = 10,620 frams
  60. #160
    Quote Originally Posted by iamspartacus View Post
    I sent you a pm,but not sure if you got it.
    My wife and I usually ride the yellow and blue trails a few times a week after work around 6 or 7 when it cools down.
    Let me know if you would like to ride sometime next week.
    Jared
  61. #161
    May 2012
    aenima, got your note and responded via private message (I believe). Any day but Wednesday next week works for me. Let's get it planned.
  62. #162
    May 2012
    finklfam, sweet photos!!!!
    Is it me, or are the Scott Sparks just a sexy looking piece of machinery?!?!?!?
  63. #163
    Yes man! and they are just like girls they're awesome then they're dirty! ha-ha
  64. #164
    May 2012
    pablobaq, so true, so true. Your dirty girl looks very nice and feisty!!!! With the rain here today, mine might get a little too.
  65. #165
    Going to be picking up one of these soon, what is better though, a spark 50 or 60 right away or a spark 70 and upgrade it? Btw, I'm a trail rider/downhill.
  66. #166
    May 2012
    Truthwalker, I have the Spark 70 because I got it at a price I couldn't say no too. All the components work great as is. I have no reason to upgrade until something breaks. The only thing you don't get on the 70 is Twin Lock. If you have the funds, go for that as it seems like a very nice feature, although, you can add it to the 70 (as I probably will do). Either way, you will get a remarkable bike that rides awesome!!!!! Welcome to the club, and post your picture when you get it!!!!!!
  67. #167
    my new 29er RC
    23.4 LB with sealant and XTR pedals, Size L
  68. #168
    May 2012
    finklfam, I almost like that color combination better then mine......almost. Very nice looking bike. I hope to get a carbon Scott one day when I earn it with my improved riding abilities. Maybe it will be the new 650b???? Hopefully they put those on a Spark.......still one of the nicest looking bikes on the market.
  69. #169
    May 2012
    Hello Spark owners , does anyone know the weight of alu 2012 Spark , frame with shock only , 26 inch version?
    And does it pedal bob much when it's pushed to the limit on uphills , on lockout mode of course?
    Thanks.
  70. #170
    Aug 2010
    Quote Originally Posted by texasnavy05 View Post
    Love them, light and subtle. 127tpi makes a difference. Weight as advertised is 540gr, they are coming in within 10%, under 600gr. Usually see them from 520 to 560
  71. #171
    I haz cheezburger now.
    I was going to break out the wife's DSLR and get artsy, but she's sore enough about me getting this thing as it is, AND I'd rather just ride the bike.
  72. #172
    May 2012
    fredzy, but has she seen how sweet that ride looks? Dang, you needed that bike!!!! Its a Scott Spark Pro.........that was a worthy investment!!!!! Ride on Spark Brotha, ride on!!!
  73. #173
    XC racer
    May 2005
    Where'd you end up finding the Pro Fredzy? Can you say?
  74. #174
    Quote Originally Posted by mtbscott View Post
    PM'd. Yea I like the 2013's a lot, and the fox/15mmQR/Shimano brakes are probably worth the premium... but had to follow my heart here
  75. #175
    Reputation: brentos's Avatar
    I took out a demo, then had to build up my own. This is what I ended up with. Not the most plush suspension, but it's the only 29er FS I could see using as a race bike, the geometry is dialed too.
    22.7 lb.
    Attached Thumbnails Attached Thumbnails Sparks...lets see em-small-spark.jpg
  76. #176
    May 2012
    brentos, very nice choices! Good luck in your races, but with that build, you won't need luck!!! Smoke 'em!!!!
  77. #177
    Reputation: TwoNin9r's Avatar
    Jan 2011
    here's my XL pro
    just picked up from LBS
  78. #178
    May 2012
    4x4runner, this is just another fine example how art is truly in the design of these bikes. Is it me, or can you just never get sick of looking at these great machines????? Very nice, very nice. So I see you are in Florida? Will this beauty be out at Santos ripping it up?
  79. #179
    Jan 2011
    to answer your first question... it's in my living room distracting me form my constitutional law homework lol, i can't stop just popping out to take a peek at it.
    to answer your second question, maybe some day i'll get out to santos but i'm pretty far south. luckily there are several trails close to me. the three closest are markham park (5 min from my house), Amelia Earhart, and Oleta River Park. then a bit farther south is Virginia Key and farther north is Quiet waters.
    i've heard great things about santos and alafia so i'll have to make it out to those on my next break from school!
  80. #180
    May 2012
    Well, get back to study time then........but I understand the need to look at her, yearning to be taken into the woods, gears opened up, racing through the outdoors........pure joy!!!!
    Now get back to the books!!!!
  81. #181
    Jan 2011
    haha great that really helped. i'm gonna get a ride in thursday morning since it's my day off.
  82. #182
    May 2012
    Thursday??? That is like 2 days away???? She's calling you, and so is the open trail just out of reach.........
  83. #183
    Jan 2011
    lol i have work and school today and tomorrow. i'm gonna probably ride around my neighborhood a bit tonight when i get home from class though.
  84. #184
    May 2012
    ok, guess that will have to do.......now stop looking in that general direction and get into those books!!!!! Plus, stop chatting online!!!! :-)
  85. #185
    Jan 2011
    just out of curiosity, what position do you guys keep your suspension link ship in? high or low?
  86. #186
    May 2012
    Unfortunately, my model (70) doesn't have that option. I was told, though, that I could do that is I just replace the plastic cover surrounding that bolt.
  87. #187
    Jan 2011
    Ohh I gocha
  88. #188
    Quote Originally Posted by 4x4runner View Post
    High was too steep and twitchy. The Low position too slack and the suspension felt saggy to me.
    I got the chip for the middle setting from the lower priced Sparks. For me it's perfect.
  89. #189
    Jan 2011
    Quote Originally Posted by brentos View Post
    brilliant! i might order one to keep it around. yeah i rode in "low" today and it was a bit too slack. required a lot of steering input...
    also, rocket rons can suck it. i miss my racing ralphs.
  90. #190
    May 2012
    I agree with the Rocket Rons. I don't know how the Racing Ralphs are, but I get a little too loose in some soft footing. I need to try some new tires.
  91. #191
    Jan 2011
    the roots felt like ice under the ron's
  92. #192
    What pressure are you running, and are you tubeless? I've been pretty happy with mine,of course I had Small Block 8's on my previous bike,so the RORO's are like super swampers to me!
  93. #193
    May 2012
    One thing I noticed on my last ride was that the Ron's got packed with soft soil/sand, so traction was reduced. Roots are always slippery, but I thought that was just because they were wet when I rode. Another thing I noticed is that my Ron's are different from other Ron's I see. It must be the tubed versus tubeless variety?????
  94. #194
    My '08 Spark 10
    I was gonna wait to post mine when I have reached my sub-7 goal, but oh well... here's mine at 7.03Kg on it's first off-road ride in the woods. I was too overwhelmed with the smooth ride down hills coming from hardtails that I only took two pictures.
    Before entering the forest:
    In the forest while trying to cut a tree that has fallen on our trail:
  95. #195
    Sorry for the huge phone pics...
  96. #196
    May 2012
    These rigs look even better in huge phone pics!!!!! Thank for sharing this lightweight beauty!!!!! Ride on!!!!!!.........by the way, how did she like the forest????
  97. #197
    Jan 2011
    Quote Originally Posted by aenima View Post
    about the same as i was running on my scale 29er.
    f- 25-26
    r- 28-30
    i'm 6'3" 215# on an XL.
    as i wrote this i thought to myself, maybe better go down in pressure out back considering i have suspension back there now... lol yes?
  98. #198
    Thanks! The bike was awesome! Coming from a hardtail background with V-brakes in all the years I spent riding a bike, traction was nothing I have experienced before! I was bombing down the hills with the rear suspension working flawlessly and the Formula R1 brakes were also confidence inspiring! My only problems were fine cuts on my arms and legs after the ride becuase I didn't expect the trails to be full of vegetation as opposed to the last time I remember riding the trail about three years ago. But it was all worth it.
  99. #199
    Sep 2012
    Here is my new '13 Spark 930! I'll get a chance to actually ride it this weekend, I can't wait. I also can't wait to get some nice pedals.
  100. #200
    May 2012
    Opening that box was probably even a better feeling then Christmas!!!!! How does Scott do it??? They made the Spark even better looking!!!! I can't wait to hear how this sweet ride rolls!!!!!! Happy Trails!
Members who have read this thread: 164
