Results 1 to 10 of 10
    Sep 2012
    Spark"29 Front Derailleur,SRAM S1 or S3??
    Hi,
    is possible change the original Front Derailleur Shimano in my next Scott Spark 910 with Sram ?
    type S1 or S3 ?
    thanks
    Beppe
    Italy
    S3 Direct Mount
    Sep 2012
    thanks pumaking,
    i want mounting rings 36-22 ,but the original front derailleur Shimano is for ring 38-26.
    bthen, i buy SRAM
    Hi,
    I have a problem to fix FD-M952 e-type to my Spark 30 2012. In the adapting plate the hole are in different distance then in the derailleur. Do you know the solution?
    Sep 2012
    confirm,serving the direct mount s3.
    i think no good for press fit BB92 mounting one e-type,and the hole is different
    in my Spark 910 2013,change the shimano original with Sram S3 for ring 36,,,perfect!!
    I want FD as a direct mount so I disassemble the carbon plate from derailleur. The problem is with the holes.
    Has the standard changed in the mean time?
    Are different adapting plates from Scott?
    No, you picked up an old E-type standard. There is no way to make that work with the new standard.
    You bought something like this
    You need something like this
    FD970 is heavy and does not look so good as FD952.
    So I have to design a new adapting plate.
    Sep 2012
    pumaking,,,the GURU of Spark
