Results 1 to 7 of 7
    Spark 10 - Should "locked out" rear shock be completely solid?
    I recently bouight a really clean 09 Spark 10. The rear shock had just been serviced by DT Swiss. I rode (raced) it today for the first time and really liked it but I noticed that even when locked out there was some movement in the rear shock! Not a lot, approx 10mm, is this normal or should the shock be completely solid?
    I like to ride my bike.
    Reputation: RideFaster's Avatar
    Dec 2004
    10mm is not bad if you were on a somewhat rough trail. When you sit on the bike, it should be pretty firm, maybe moving 3mm at most.
    I like bicycles. Bicycles make me happy. Riding them makes me even happier.
    Scott Bicycles
    Maxxis Tires
    Team Blog
    slap-tanker
    Reputation: tank-slapper's Avatar
    It won't be completely solid, but 10mm sounds a lot. Check the pressure.
    In the UK? Try these routes in the Peak District:
    http://www.brassington.org/new_site/...ike_routes.htm
    addicted
    Reputation: willrace4food's Avatar
    Jan 2009
    make sure the cable is pulling the lockout all the way to the stop as well
    Reputation: Richy's Avatar
    Yup. Not having it to the stop on the shock makes a big difference.
    UK-Biking Shop now live - Also follow us on Facebook and Twitter
    Jun 2010
    Yes.Remote lever cable adjust could be the problem. It is easy to check.
    The Cheater
    Reputation: Veda's Avatar
    Dec 2009
    Mine locked completely like a hardtail. There's something wrong if it moves by 10mm...
