    Nov 2008
    Scott Genius 740 - Which rear 142x12 axle?
    I have a 2013 Scott Genius 740 with the IDS-SL interchangeable rear dropout system. It is currently set up with the stock 135x5 DT RWS skewer but I bought the 142x12 IDS dropouts and bought a wheelset with a 142x12 axle rear wheel. My question is what axle should I be using? I understand there are two different axle standards. The Shimano standard that is used in the RockShox Maxle and the X-12 standard. I believe the X-12 uses a tapered interface with the dropouts and the Maxle has a flat interface. It appears that my dropouts are flat...should I just use a Maxle or does DT make an axle that I should use?
    Use Shimano
    Dt swiss makes one
    Nov 2013
    My 740 2013 is also with 135x5 and want to make the chances to the 142x12, where did you buy the dropout??
  1. Replies: 2
    Last Post: 09-10-2013, 01:41 PM
  2. chinese carbon HT frame with 142x12 rear axle?
    By simpy16 in forum 29er Bikes
    Last Post: 11-17-2012, 06:34 PM
  3. Replies: 1
    Last Post: 10-06-2012, 08:14 PM
  4. Scott Genius MC40 rear shock issues
    By J1mmys in forum Scott Sports
    Last Post: 06-25-2012, 11:46 AM
  5. Replies: 1
    Last Post: 03-08-2012, 09:38 AM
