the pedal arms are worn on the outer ends due to them striking the ground even when I don't corner that aggressively on tarmac. Is the rear suspension misadjusted or is there another angle somewhere I can change to raise the pedal axle above the ground?
I also think the handlebar is too high, is there another piece between the upright steering pool and the central part of the handlebars I can buy to lower it?
Wider handlebars would be nice too.
- Adam -
Scott Genius 60 - pedals strike ground too often - handlebar too high-p1030410-small.jpg
