Results 1 to 3 of 3
    scott g zero fx bushes for rear shock
    replacing x fusion glyde rpv with fox float rp3
    the fox float came with out bushes
    does anyone know what bushes i'd need and how to put them on?
    Reputation: Fillet-brazed's Avatar
    They just press in to the shock eye. I find vice-grips work well for pulling them out. Measure the width of the shock mount (both ends) and subtract the width of the shock. The number you come up with is the thickness of spacers you need. There's a decent chance the spacers in your X fusion will also work on your fox shock.
    Reputation: miggy's Avatar
    Nov 2008
    Quote Originally Posted by sublime_mick
    did you notice if the RP3 larger o.d air resivour fowels the frame when fully compressed?
    keen to replace my DT swiss 210L, your thought woudl be a bug help
    Rolling & Tumbling
