Results 1 to 5 of 5
    Scale - sizing question?
    I'm in the process of changing my 2010 Spark 10 and I'm going to buy a Scale 900 RC! I'm 5'11" (180cm) and my Spark is a medium which I've always felt is a fraction too small for me (I run a 110mm stem). It has a 585mm horizontal TT. From 2011 the Scale/Spark geometry changed and the current medium Scale has a TT length of 600mm. So that would seem to be about right for me? But the Scott sizing chart puts me firmly in the "Large" territory which has a TT length of 620mm! Expensive bike so don't want to make the wrong choice ..... what do you guys think?
    I think you could go either size depending on your preference. I'm a 1/2" shorter than you with a 32" inseam and have been on a medium since the frame became available. About a year ago I went thru a phase where I was thinking a longer TT with a shorter stem would better serve me, so built up a Large frame. The Larger frame felt a little more stable but sacrificed the nimble handeling of the Medium frame. I really think fit is very rider specific, what I like may not respond to your liking, do you have access to a M and L frame for a demo?
    Generally, I have found that customers that are sized on the Spark can transfer to the Scale of the same size with success, and vice-versa. So if the Med Spark feels a bit too short in the Cockpit, the Med Scale likely will too.
    Thanks guys - appreciate the feedback!
    I'm also 180 cm. I have a Spark (2010), a Scale 29, a Scale 26 and a Addict. All in Size L.
  1. 2013 Scale 29er - sizing question
    By S-Worker in forum Scott Sports
    Last Post: 10-01-2012, 04:11 PM
  2. Scott Scale RC/Pro 29 frame sizing
    By digit3 in forum Scott Sports
    Last Post: 11-08-2011, 04:48 AM
  3. Help with sizing a Scale 29er
    By daniel240 in forum Scott Sports
    Last Post: 09-14-2011, 06:54 AM
  4. Scale 29 Elite - Ride and Sizing
    By Tinshield in forum Scott Sports
    Last Post: 07-04-2011, 06:29 PM
  5. scale 29er sizing
    By epicracer5 in forum 29er Bikes
    Last Post: 02-26-2011, 06:12 PM
