Results 1 to 5 of 5
    Scale Carbon Frame: Rear Brake Bolt Torque?
    I recently purchased a Scott Scale 620 with carbon fiber frame. I want to determine the correct torque for tightening the rear disc brake (Shimano SLX) attachment bolts to the carbon frame. I haven't been able to locate this info anywhere, would somebody be kind enough to give me a hint? thanks
    Dec 2011
    Quote Originally Posted by afalts View Post
    this is a great resource, thanks a lot!
    it doesn't really mention carbon frames though, and my concern is that the rear caliper bolts on the Scale go right into the carbon frame...i want to take it apart to see if maybe there's something metal inside the carbon that it screws into but then I won't know how tight to make it when I put it back together :-)
    Dec 2011
    Yes, there is a metal insert, the brake rests on that and not the carbon. It is very rare to see something that is threaded into carbon, there is almost always a metal insert of some kind
    thanks! this makes a lot of sense, now I won't be afraid of working on it when the time comes.
  1. Halp!! Frame pivot bolt torque spec. '02 Tracer.
    By RichardHead in forum Intense
    Last Post: 04-10-2013, 10:16 AM
  2. Bolt-on rim brake posts for a carbon fork ?
    By phoenixbikes in forum Weight Weenies
    Last Post: 01-19-2013, 08:57 AM
  3. Which carbon frame - scott scale or Highball
    By ayogev in forum 29er Bikes
    Last Post: 10-13-2012, 11:37 PM
  4. Scale 29 Carbon frame question
    By mark43 in forum Scott Sports
    Last Post: 01-10-2012, 10:16 AM
  5. Rear shock bolt torque spec?
    By slideways666 in forum Ibis
    Last Post: 02-27-2011, 02:13 PM
