Results 1 to 13 of 13
    Aug 2005
    Scale 29 Carbon frame question
    The Scott Scale 29 RC has received glowing reviews. If I could afford one, I would buy it. I am looking at the Scale 29 Pro, which is more in my price range. Obviously, the Expert and the Pro have different frames than the RC; is there a tremendous difference in frame quality? I know that a lot of lower cost carbon frames (road and mountain) are made with vastly different carbon layups and designs which greatly affect weight and ride quality. I don't want to buy a carbon bike just to have a carbon bike; I want to know I am getting a good ride, not just a good deal. Any input appreciated.
    Reputation: Billy Davis's Avatar
    Dec 2011
    Scale
    Good question I'm looking at one as well and would like more details. I'm currently on an AL version and love the ride.
    Reputation: bellullabob's Avatar
    the Pro and Expert frame weight more than the RC by about 150 grms I believe. I can tell you that the expert carbon frame really does absorb the trail chatter a lot! In a blind taste test, I don't think most folks will be able to tell the difference between the Rc and the Pro, but they should be able tell the difference between the carbon vs the alum versions!
    Before you buy anything online, send Bob at bikerbob.com an email! Best online retailer!
    My bike/ race Blog
    Your Best Friend
    Reputation: Silentfoe's Avatar
    The RC uses HMX carbon which lighter and stronger than the HMF carbon used on the lower models. This means they can use less carbon fiber in the build of the frame but get the same strength. The frames should ride the same, the RC will just be lighter.
    I'm a mountain bike guide in southwest Utah
    Because of the stiffness, the RC has a firmer ride as opposed to the Expert/Pro.
    The difference in weight has nothing to do with the front triangle. The RC is the only model w/ a full carbon front and rear triangle, the Pro/Expert frames have the same carbon front triangle and aluminum rear triangle. Hope that helps.
    Chris
    Your Best Friend
    [QUOTE=pumaking;8880385]Because of the stiffness, the RC has a firmer ride as opposed to the Expert/Pro.[/QUOTE
    I have ridden an RC for thousands of miles and a Pro for almost 100. The only difference I could feel was in how the bike was set up, not frame stiffness. So, IMO this is not true.
    [QUOTE=WaitWienie;8880426]The difference in weight has nothing to do with the front triangle. The RC is the only model w/ a full carbon front and rear triangle, the Pro/Expert frames have the same carbon front triangle and aluminum rear triangle. Hope that helps.
    Chris[/QUOTE
    Huh? The RC/Pro/and Expert are all COMPLETELY carbon.
    Per Scott Website for the PRO: Alloy Swingarm
    Spark Carbon, IMP5 technology, HMF NET, BB 92, Alloy swingarm with 160PM, U-Mono Link, Tapered Headtube, IDS SL dropouts for 142 x 12mm, BB height adjustable, 100mm rear travel
    Per Scott Website for the RC: Carbon Swingarm
    Spark Carbon, IMP5 technology, HMX NET, BB 92, Carbon swingarm with 160PM, U-Mono Link, Tapered Headtube, IDS SL dropouts for 142 x 12mm, BB height adjustable, 100mm rear travel
    Like I said the only differance is the rear swingarm that is the extra weight. Front Mainframes are exactly the same.
    Chris
    WaitWiene,
    You are quoting information about the Scott Spark, which has a full suspension frame. This thread and the OP's original question concern the Scott Scale, which is a hardtail.
    Your Best Friend
    Quote Originally Posted by coldryder View Post
    WaitWiene,
    Thanks. +1
    Damn I didn't look at that. I always get the two names mixed up. Sorry.
    Chris
    Good thing I've ridden more miles, on a wide assortment of terrains, raced both. I've had pro's, expert's ride both and all have confirmed the RC was harsher. So, IMO it is true.
    Quote Originally Posted by pumaking View Post
    I bet the difference would be like less than 1/2 a psi in your tires. So if you can tell the difference between having 27 1/2 psi in your tires vs 28 than you might be able to feel the difference.
    My bike/ race Blog
  1. down tube protection for carbon frame? scale 29er
    By willymcd in forum Scott Sports
    Last Post: 12-26-2011, 10:16 PM
  2. Scale Carbon 2011 frame 950 grams
    By redbyte in forum 29er Bikes
    Last Post: 10-30-2010, 05:26 AM
  3. Replies: 7
    Last Post: 02-08-2010, 01:02 PM
  4. Scale 10 frame set & headset question
    By quax in forum Scott Sports
    Last Post: 04-03-2009, 01:54 AM
  5. Scott Scale frame size? Scale owners??!!
    By -wanderer- in forum Bike and Frame discussion
    Last Post: 02-03-2006, 02:02 PM
