Results 1 to 9 of 9
    Knocking noise coming from fork/headset/headtube
    Hello all about a month ago i bought a scott scale 730 carbon hard tail. The bike as of late has been making a knocking noise every time i hit a large root or obstacle when riding. It also makes this knocking noise if i slam the front brake very hard randomly. If i pop the front tire up and bring it down hard it will also make the noise. I have tightened the stem 3 times and it still makes the noise. Do you guys have any insight on what it can be? The noise seems to be coming from fork/headset/headtube area thanks!
    Apr 2014
    From your description I'm thinking you tightened the stem before tightening the headset top cap first, so loosen the stem then tighten the top cap just enough so there's no play in the fork and finally tighten the stem.
    Hope this helps
    Sent from my Nexus 5 using Tapatalk
    Reputation: shiggy's Avatar
    Dec 1998
    Re: Knocking noise coming from fork/headset/headtube
    Quote Originally Posted by jojemoruga View Post
    Hope this helps
    And/or the top cap is bottoming out on the steer tube and needs another spacer.
    mtbtires.com
    nope i tightened the top cap first and then the two side ones. And the bike is 100 percent stock so doesn't make sense that it would need a spacer it came from the factory like that
    Dec 1998
    Quote Originally Posted by chippedgti View Post
    May not make sense (to you) but it is entirely possible and easy to check.
    mtbtires.com
    it the noise apparent only when you have the brake applied? will it happen when your hands are off the brake levers?
    I have a 2013 genius that does the same. I'd describe the noise as a 'tick' rather than a knock however. I think it's in the fork in my case, a 29er 32mm fork is probably on the weak side for this bike. I'm replacing the seals/oil soon and will inspect the fork while it's off the bike.
    My brother has a 26er fox fork that does the same thing.
    Feb 2015
    In addition to the OP, I too have this issue. I recently purchased the entry level Aspect 950 about a month ago, I dont ride double black diamonds or techincal riding but the guys at my lbs looked at me like I'm nuts and dont know what I'm talking about. I ride pretty much the same trails, not much variation and this wasn't happeneing before and it recently started during my last 2 rides. So I picked it up from the shop - they tightened the stem and "checked it out". So I rode it and its still going on, bummer. I'm guessing its just due to a not-so-great fork. To the OP, any updates ?
    assuming you have centerlock rotors, check that the locknut is torqued properly. If it isn't, you will get a knocking under heavy braking or a heavy bike knock.
  1. Knocking Noise From Headset/Fork
    By chippedgti in forum 27.5
    Last Post: 06-24-2014, 12:35 PM
  2. Knocking noise coming from headset/stem area?
    By Norcoshore1 in forum Downhill - Freeride
    Last Post: 06-19-2014, 08:46 PM
  3. Noise coming from the headset or somewhere near it
    By Citi in forum Beginner's Corner
    Last Post: 05-09-2013, 12:50 PM
  4. Creaking noise coming from carbon headtube
    By GS833 in forum General Discussion
    Last Post: 08-22-2012, 07:57 AM
  5. Noise coming from my headset/fork
    By outdoorz in forum Bike and Frame discussion
    Last Post: 07-14-2012, 06:18 PM
