Results 1 to 3 of 3
    May 2013
    How do I put this DT Swiss Nude 2 shock cable Pulley back?
    From time to time, I take DT Swiss Nude 2 shock apart to grease the seals with Slick honey. Shock performs good as new. But eventually mud and grime found its way into the CTD cable pulley assembly. It was making gritty sounds so i decided to took it apart. Bad idea. Pulley uncoiled and initial position of the shaft is lost. I can't find any documentation to put it back together. No instructions. Can someone help me?
    Here's a link to how you would 're-clock' the older Nude 1 remote wheel:
    http://www.google.co.uk/url?url=http...qvxM6p7WJ_FO6A
    Perhaps you can use a similar principle on the Nude 2?
    May 2013
    Unfortunately Nude 1 instructions do not apply to Nude 2.
    Here is the reply from DT Swiss USA. I'm putting their e-mail here for future reference.
    Put the long arm of the spring into the small hole next to the shaft.
    Align the shaft and put the short arm of the spring into the wheel.
    Shaft and wheel must be positioned like shown in the picture!
    Put the short arm of the spring into the hole of the remote wheel.
    Put the remote wheel slightly onto the shaft.
    Turn the remote wheel approximately 270 using a 4 mm Allen key.
    Push the remote wheel down so that it is fixed.
    Degrease the screw of the remote wheel.
    Put Loctite 241 onto the screw of the remote wheel.
    Put in the screw of the remote wheel using a 2.5 mm Allen key and tighten it hand tight.
  1. Sticky/Stuck return to open mode on Nude 2 shock
    By bryanus in forum Scott Sports
    Last Post: 07-16-2014, 02:16 PM
  2. Replies: 9
    Last Post: 04-30-2014, 09:41 PM
  3. Scott Nude Shock Service & Maintenance Manual
    By tate6969 in forum Scott Sports
    Last Post: 08-17-2013, 11:24 PM
  4. Got DT Swiss Nude spare parts?
    By simmons77 in forum Scott Sports
    Last Post: 08-19-2011, 09:29 PM
