Results 1 to 3 of 3
    Jul 2014
    help, spark carbon 2009 headset
    does anyone know if the lower headset can be removed or is it glued to the frame??
    Pressed-in and can easiley be removed BUT DO NOT USE A CONVENTIONAL CUP REMOVER. Above both cups there is a carbon reinforcing ring - if you insert a normal cup remover, you will be smashing against this ring. The rings have 2 slots (180degs opposed) - insert a long flat-head screwdriver and tap the cup out, via the slots.
    Jul 2014
    thanks.
    works perfect!!!
    now, i have a big problem.
    i slide down the head tube the tapered fork and it does´t fit.
    the internal carbon head tube is too narrow.
    is it possible to cut down the inner base of the lower cup inside the head tube.?
  1. Scott Spark 2009 - Too old?
    By Brockwan in forum Beginner's Corner
    Last Post: 08-08-2013, 02:12 PM
  2. Replies: 1
    Last Post: 02-06-2013, 05:21 PM
  3. Replies: 0
    Last Post: 02-06-2013, 01:50 PM
  4. Replies: 2
    Last Post: 04-05-2012, 09:53 AM
