Results 1 to 6 of 6
    Got A Ransom? Want to try 27,5/650B? Works pretty fine!
    So, just want to report that the Ransom is an excellent 650B conversion object. All you need is a whole new wheelset (doh!) with a 12mm/135mm rear axle and a new set of 12mm dropouts.
    By coincidence I found that there are an alternate IDS 12mm "long" dropout available for the old Gambler and Voltage that is 10mm longer than the standard. This actually brings the axle about 8mm backwards and 5mm upwards, which works out well for adding slightly bigger wheels. After some planning and waiting for good wheel deals I have fitted a pair of 21mm (inner) Superstar Sentinel wheels. With a 2.25 ardent in the rear i have about 11mm to the seatstay bridge which is pretty normal distance on a 26" and the standard dropouts. I already had a Suntour Durolux up front and that gives me around 10mm clearance too so no need to change that.
    The only niggle is that this of course raises the bottom bracket quite a bit. This I have corrected with a couple of 3mm offset bushings, bringing the BB down to about 354mm (13,9"), still a bit high but quite ok for me, riding quite technical trails, lots of pedal hits. The offset of course slacks the head angle about a degree as well but I actually had a slackset on the frame already to slack it out whick i took off and ended up at a HA of about 66. That's perfect I think.
    So I have spent about 250 on it and got a completely new bike. And I actually think it was a good investment, the bike feels more capable and actually fits the 165mm of travel quite well. Easier to roll over technical terrain and climbs surprisingly well. This while not losing any of the agility. And I think it is a quite noticeable difference.
    And some pics to prove it.
    Attached Thumbnails Attached Thumbnails Got A Ransom? Want to try 27,5/650B? Works pretty fine!-img_20140519_234621.jpg
    Got A Ransom? Want to try 27,5/650B? Works pretty fine!-img_20140517_171126.jpg
    roadrunna
    Looks good, can you post a picture of the clearance in the front? I'm running a Durolux and a Commencal Meta HT 650 frame. Right now I'm running it with 26' wheels and want to see what I'm looking at if I just switch out the wheelset and keep my Durolux. It's a wonderful fork! Thanks!
    Durolux Clearance
    Sure, no problem. I spent a lot of time trying to find a reference from somebody that hade tested and eventually found someone in germany who showed about 10mm clearancce so I decided to take the plunge. This is with a maxxis high roller 2.35 and 21mm inner width rims.
    Got A Ransom? Want to try 27,5/650B? Works pretty fine!-img_20140517_171356.jpg
    Aug 2010
    Interesting mod. I wonder if my Bos Devilles (26in) will take a 650b wheel...Id love to try this
    Looks like the deville will fit a 650B in the lowers but you might want to put in a 5-10mm spacer to keep the crown clear of the tyre when bottoming.
  1. S-Works Cranks on Ibis HDR 650b?
    By HeatmiserSoCal in forum Weight Weenies
    Last Post: 07-06-2013, 09:45 AM
  2. Replies: 54
    Last Post: 02-06-2013, 08:24 AM
  3. 2011 S-Works HT 650B compatability?
    By wetpaint in forum 27.5
    Last Post: 11-17-2012, 10:29 AM
  4. 650b Epic S-Works 2011
    By dns76 in forum 27.5
    Last Post: 10-22-2012, 05:08 AM
  5. GT Zaskar Pro Carbon HT + 650B = it works
    By venga venga venga in forum 27.5
    Last Post: 09-09-2012, 10:03 PM
