Page 8 of 10 FirstFirst ... 4 5 6 7 8 9 10 LastLast
Results 176 to 200 of 238
  1. #176
    Nov 2013
    I made the swap to a genius 740 shock 200x57mm and hardware 8x22mm i went with a fox ctd but for rockshox they should not change.
  2. #177
    May 2014
    Quote Originally Posted by stephanmoll View Post
    Thats correct 200/57 why no cane creek there is another forim of a genius 930 with one an no problem?
    I went with fox boost valve ctd and perfect fit.
    Sent from my GT-I9300 using Tapatalk
    Quote Originally Posted by MikeQueyar View Post
    Thanks for taking the time in responding, good to know. Have a great weekend.
  3. #178
    OK, so if I have a 2013 Scott Genius 930 (29er), what size Fox rear shock would I need? I am seeing the whole 29er and 650b back and forth conversations since the beginning of this thread and have become thoroughly confused now... I just want to make absolutely sure that if I pull the trigger I am buying the correct shock... Ideally would like the Float X CTD, but would be fine with a lesser model depending on budget.
    My searching for DT Swiss support for seal kits or maintenance instructions have become more frustrating than they are worth, so this is my next best option.
    Thanks for any input!
    2011 C-Dale Flash 1 650b
    2015 Charge Cooker Maxi
  4. #179
    Reputation: stephanmoll's Avatar
    Yes it sucks dt swiss, in my opinion wait for cane creek inline I have the fox ctd factory and feel to lineal and goin to make a swap to cane creek.
  5. #180
    Reputation: weaverwins's Avatar
    Dec 2008
    Quote Originally Posted by A-Ray View Post
    this email is from fox sometimes last year when i asked the same question of them for my 2013 genius 910. i ended up going with the cane creek db air cs but the float x looks awesome too.
    With that bike you can fit any of our air rear shocks. As far as remote goes you can get either the FLOAT CTD Remote at $470.00, or you can get the FLOAT X for $595.00. The price for both of these is without the remote. The size of that shock is 7.5” x 2.0”.
    Scott Genius 910 tricked out as much as I could without getting a divorce
  6. #181
    Nov 2013
    You changing again bro.....Im making a frame swap the bronson will arrive by the end of this month.
    Are you selling the fox ctd kashima??? I may be interested on buying it the measure are the same for the bronson 200*57
  7. #182
    Yes I am selling it!!!!
  8. #183
    Re: Fox shock on 2013 Genius
    No way I am looking at a bronson frame too were u abke to sell your scott frame quick?
  9. #184
    Quote Originally Posted by weaverwins View Post
    Thanks for the great info! Looks like I will be going this route...
  10. #185
    Hi guys, I'm looking to do this swap on my 710 (2013). Sorry to beat a dead horse here, but can you confirm the shock hardware size and shock length? The Scott manual for the 2013 Genius shows 6x22.2 hardware and 200x55 shock length (which probably translates to 200x57 (7.875 x 2.25) for the Fox CTD), but the thread seems to say 8x22 is the size.
    Where's a good source for the hardware?
    TIA.
    Here's a screenshot from the manual:
    Wanted: Ritchey P-20,21,22,23 in Team colors, 18-inch, '92-99, Ritchey Logic fork (threadless); NEW Rock Shox Judy Decal Sets
  11. #186
    I got my hardware on jensonusa.com 22.2 x 8 but my genius is 730 though
  12. #187
    Interesting, I wonder if the carbon vs aluminum frames have different spacing then? The manual I picked up that information from seemed to cover both versions, however. Thanks for the tip for jensons!
  13. #188
    Dec 2008
    Quote Originally Posted by bryanus View Post
    Contact fox (or cane Creek etc) and they'll tell you which shock fits.
  14. #189
    Nov 2013
    My was 200x57 and hardware 22x8
    I sole my to a friend and he hasnt had any problem untill this day.
  15. #190
    May 2013
    Anyone else considering the Cane Creek Inline?
    The reviews seem to be pretty favorable on Cane Creek's new DB Inline shock and seeing how its the only Cane Creek model that will fit my 940 Genius, any opinions?
    2012 GT Karakoram
    2013 Scott Genius 940
  16. #191
    Dec 2008
    Quote Originally Posted by Rogue426 View Post
    i might have gotten that for my 910 had it been out. ive heard that unless youre doing extended downhill runs, the piggyback isn't a bonus. couldnt be happier with my CC DB Air CS as it completely transformed my genius and made it ride how i hoped it would out of the box but like i said, the inline wasnt an option at the time.
  17. #192
    Yes the inline seems solid I am goin to swap my ctd for cane creek.
  18. #193
    May 2013
    Do you know how many sets of 8x22mm bushings are needed? 2? One for the piston side and one for the Chamber side?
  19. #194
    2 sets
  20. #195
    May 2013
    May 2013
    Just verified with Scott the the shock dimensions for the Genius 700 SL is 200mmx55mm
  22. #197
    What shock cane creek?
  23. #198
    If you take a look at the Genius 2013 Owner's Manual it shows that Genuis 700 and Genuis 900 are different regarding the size of the shock
    http://assets.scott-sports.com.s3.am..._Genius_EN.pdf
    I bought the 7.5 x 2.0 (190mmx50mm) because I have 900 Frame.
  24. #199
    May 2014
    Anyone run into any issues with a 2014 or 2015 Fox Float CTD on a 2013 Scott Genius 940 (size 190mm x 50 mm)? Scott still won't provide any details when I contact them. I want to make this switch this summer. Otherwise, I will have to spend the money on an CC inline...
  25. #200
    I will recomend waiting for the cc inline much better shock
    And been on fox ctd genius 730 2013 no issues here
  1. genius 2013
    By sworksflux in forum Scott Sports
    Last Post: 08-06-2012, 03:23 PM
  2. Genius 2013
    By zedi in forum Scott Sports
    Last Post: 07-24-2012, 12:55 PM
  3. scott genius 2013 650b?
    By zombinate in forum 27.5
    Last Post: 07-05-2012, 06:12 AM
  4. Genius 10 shock leverage ratio replacement shock?
    By protocol_droid in forum Scott Sports
    Last Post: 11-01-2011, 05:24 PM
  5. 06 genius shock pressures
    By superspec in forum Scott Sports
    Last Post: 05-01-2011, 03:59 PM
