Page 4 of 5 FirstFirst 12345 LastLast
Results 151 to 200 of 238
  1. #151
    Reputation: biggazu's Avatar
    Dec 2008
    A little update, I now have a fox ctd remote 2013 shock,
    Which works better than the DT Swiss with the twinloc.
    So the question is, why does Scott not want you to do this upgrade. Mojo suspension said it would fit, wouldn't hit the down tube and would work fine
    with the twinloc!!!!!!Fox shock on 2013 Genius-1970408_10203264119822846_1385986765_n.jpg
  2. #152
    Nov 2013
    Rock on \m/
  3. #153
    Reputation: stephanmoll's Avatar
    Nice !!!
    Sent from my GT-I9300 using Tapatalk
  4. #154
    Nov 2013
    Biggazu, you got this shock to work with the twinloc?
  5. #155
    Dec 2008
    Quote Originally Posted by Hextall View Post
    Yes, it works a treat, bit too easy to mount and setup, Was a doddle.
    Keep thinking ive done some thing wrong. cycled thru all the settings on
    twinloc and it just works better than the dt swiss.
  6. #156
    Feb 2014
    Amazing,did you have to change the disc in the twinloc from DT Swiss to a Fox one.
  7. #157
    Dec 2008
    Quote Originally Posted by wock View Post
    Done nothing to the fox ctd. Just threaded the cable,
    Took up the slack. That's it.
  8. #158
    Feb 2014
    how much for the remote ctd shock.
  9. #159
    Reputation: Rhinodriver's Avatar
    Feb 2014
    Quote Originally Posted by biggazu View Post
    What size was the shock and hardware? Looks great. I'd like to use the same setup.
  10. #160
    Dec 2008
    ... and if we just ...
    Quote Originally Posted by Rhinodriver View Post
    The Fox Float CTD is a 200 x 57mm with a medium tune and 175 psi boostvalve.
    bushing are 8x22mm which my good friend on here Mike told me to buy. other than that, that's it, New inner and outer cables help. Mine are on order.
    Plus I did a 20.7 mile ride Garmin Connect
    The bike was SWEAR WORD EPIC EPIC EPIC. It rides just like it was designed to do, and very very well. The shock was a lot of uk sterling. But worth as much as a very good set of wheel. The climb mode with the high compression is way better than having the shock locked fully out. Plus the decent open mode is also like coil spring smooth. Worth ever £££££ Why on earth Scott didn't put the fox CTD Float shock on from new is blinding.
  11. #161
    Feb 2014
    Thanks man! Glad to hear it rides so good... Now to figure out how to pay for it.... Not sure my moonlighting as a slightly overweight, middle aged, bald gigolo is going to get me there!
  12. #162
    Nov 2013
    I had budget trouble too so I got a 2013 float CTD on sale for 258 on probikesupply and it works great Im hitting the trail really good with that shock.
    If I had the cash I would go for the fox float x but the ctd work just fine....
  13. #163
    Dec 2013
    Hi!
    Great info!
    First post in this Great forum!
    Got inspired and bought a Fox float CTD 2014 of ebay
    yesterday. 225$ incl shipping. Hope this shock will work
    better than stock on my 740...
    Mods done so far:
    Richey carbon riser bar
    Xt brakes and gearshifters
    Converted wheels tubless
    Tmars dropper post
  14. #164
    Good price I got my ctd kashima at 300 and what a diference.
  15. #165
    Nov 2013
    Quote Originally Posted by abris76 View Post
    Hi!
    Great info!
    if you ordered the 200x57mm and hardware 8x22mm there will be no problem and you will have a better bike....
  16. #166
    Dec 2008
    Hi!
    Great info!
    Mods done so far:
    Tmars dropper post
    If you not smiling like Bill Gate when he checks his bank balance, some thing is wrong.
    That's how good the bike is with the Fox shock.
  17. #167
    I'm not sure why Scott UK advise against fitting a Fox shock. There must be a reason (perhaps an issue on smaller sizes?). Perhaps the odds of the shock head hitting the underside of the top tube are VERY slim, but tests proved that with all the worst-case scenarios it may happen ie small frame, large rider, frame flex etc etc. They can't say it will work for this and not for that, otherwise they open themselves up to all the legal rubbish.....
    Anyway biggazu - are you in the UK as well?
  18. #168
    Dec 2013
    That what's I'm hoping!
    Got 200*57 incl correct spacers.
    Was unused, came of a Bronson...
    Just wait and see.
  19. #169
    Dec 2008
    I did get an answer from Scott UK, the reply is on the forum. The Fox Nude shock off the 2014 won't fit, The head of the shock might hit the top tube. I didn't fit a nude, I took advise from Mojo fox. The Fox float ctd I installed has a lot of clearance, I would not risk it if it wouldn't work. Funny how many pro riders have Scott genius, but none use the DT Swiss shock!!!!
    If you look at the picture above, you can see what sort space between the shock and the down tube, it had less with the dt swiss.
  20. #170
    Feb 2014
    Im in the UK. CWS.
    Live in the Forest Of Dean.
  21. #171
    Apr 2014
    Hi
    Would the set up you describe work on a genius 940 ? I would love to change my Swiss DT shock for something that works as I love the bike.
    Steve
  22. #172
    Quote Originally Posted by Oldjoe sew View Post
    Hi
    Steve
    I have a 900 SL which geometry is the same as the 940. I installed the Float X without any trouble, fits perfect, I had a problem with the return spring on the shock but Fox took care of it and now the shock is working as planned. I'm using the twinlock system, not the Fox CTD remote lever, the riding is unbelievable better. You won't regret it....
  23. #173
    Apr 2014
    Goodbye fit swiss rear shock
    Quote Originally Posted by hvmathews View Post
    Thanks will get looking for one
  24. #174
    May 2014
    Hey folks, so glad I came across this post. Have a 2013 Scott Genius 740 which I have customised a fair amount (X01 Groupset, reverb, Hope brakes etc) and have now turned my attention to the shock.
    Can I just confirm that it's a 200x57 shock I need rather than a 200x51?
    Checking the Cane Creek website, they have suggested the latter due to the possible issue with frame strikes at full compression but reading the posts, it seems 200x57 is fine.
    Will be going with a Monarch+ shock rather than the CC and will pair that with a Pike up front but want to ensure I get the right one. Would it make a huge impact if I went with the recommended 200x51 size or are CC just playing it safe.
    Thanks folks
  25. #175
    Thats correct 200/57 why no cane creek there is another forim of a genius 930 with one an no problem?
    I went with fox boost valve ctd and perfect fit.
  26. #176
    Nov 2013
    I made the swap to a genius 740 shock 200x57mm and hardware 8x22mm i went with a fox ctd but for rockshox they should not change.
  27. #177
    May 2014
    Quote Originally Posted by stephanmoll View Post
    Quote Originally Posted by MikeQueyar View Post
    Thanks for taking the time in responding, good to know. Have a great weekend.
  28. #178
    OK, so if I have a 2013 Scott Genius 930 (29er), what size Fox rear shock would I need? I am seeing the whole 29er and 650b back and forth conversations since the beginning of this thread and have become thoroughly confused now... I just want to make absolutely sure that if I pull the trigger I am buying the correct shock... Ideally would like the Float X CTD, but would be fine with a lesser model depending on budget.
    My searching for DT Swiss support for seal kits or maintenance instructions have become more frustrating than they are worth, so this is my next best option.
    Thanks for any input!
    2011 C-Dale Flash 1 650b
    2015 Charge Cooker Maxi
  29. #179
    Yes it sucks dt swiss, in my opinion wait for cane creek inline I have the fox ctd factory and feel to lineal and goin to make a swap to cane creek.
  30. #180
    Reputation: weaverwins's Avatar
    Dec 2008
    Quote Originally Posted by A-Ray View Post
    this email is from fox sometimes last year when i asked the same question of them for my 2013 genius 910. i ended up going with the cane creek db air cs but the float x looks awesome too.
    With that bike you can fit any of our air rear shocks. As far as remote goes you can get either the FLOAT CTD Remote at $470.00, or you can get the FLOAT X for $595.00. The price for both of these is without the remote. The size of that shock is 7.5” x 2.0”.
    Scott Genius 910 tricked out as much as I could without getting a divorce
  31. #181
    Nov 2013
    You changing again bro.....Im making a frame swap the bronson will arrive by the end of this month.
    Are you selling the fox ctd kashima??? I may be interested on buying it the measure are the same for the bronson 200*57
  32. #182
    Yes I am selling it!!!!
  33. #183
    Re: Fox shock on 2013 Genius
    No way I am looking at a bronson frame too were u abke to sell your scott frame quick?
  34. #184
    Quote Originally Posted by weaverwins View Post
    Thanks for the great info! Looks like I will be going this route...
  35. #185
    Hi guys, I'm looking to do this swap on my 710 (2013). Sorry to beat a dead horse here, but can you confirm the shock hardware size and shock length? The Scott manual for the 2013 Genius shows 6x22.2 hardware and 200x55 shock length (which probably translates to 200x57 (7.875 x 2.25) for the Fox CTD), but the thread seems to say 8x22 is the size.
    Where's a good source for the hardware?
    TIA.
    Here's a screenshot from the manual:
    Wanted: Ritchey P-20,21,22,23 in Team colors, 18-inch, '92-99, Ritchey Logic fork (threadless); NEW Rock Shox Judy Decal Sets
  36. #186
    I got my hardware on jensonusa.com 22.2 x 8 but my genius is 730 though
  37. #187
    Interesting, I wonder if the carbon vs aluminum frames have different spacing then? The manual I picked up that information from seemed to cover both versions, however. Thanks for the tip for jensons!
  38. #188
    Dec 2008
    Quote Originally Posted by bryanus View Post
    Contact fox (or cane Creek etc) and they'll tell you which shock fits.
  39. #189
    Nov 2013
    My was 200x57 and hardware 22x8
    I sole my to a friend and he hasnt had any problem untill this day.
  40. #190
    May 2013
    Anyone else considering the Cane Creek Inline?
    The reviews seem to be pretty favorable on Cane Creek's new DB Inline shock and seeing how its the only Cane Creek model that will fit my 940 Genius, any opinions?
    2012 GT Karakoram
    2013 Scott Genius 940
  41. #191
    Dec 2008
    Quote Originally Posted by Rogue426 View Post
    i might have gotten that for my 910 had it been out. ive heard that unless youre doing extended downhill runs, the piggyback isn't a bonus. couldnt be happier with my CC DB Air CS as it completely transformed my genius and made it ride how i hoped it would out of the box but like i said, the inline wasnt an option at the time.
  42. #192
    Yes the inline seems solid I am goin to swap my ctd for cane creek.
  43. #193
    May 2013
    Do you know how many sets of 8x22mm bushings are needed? 2? One for the piston side and one for the Chamber side?
  44. #194
    2 sets
  45. #195
    May 2013
    May 2013
    Just verified with Scott the the shock dimensions for the Genius 700 SL is 200mmx55mm
  47. #197
    What shock cane creek?
  48. #198
    If you take a look at the Genius 2013 Owner's Manual it shows that Genuis 700 and Genuis 900 are different regarding the size of the shock
    http://assets.scott-sports.com.s3.am..._Genius_EN.pdf
    I bought the 7.5 x 2.0 (190mmx50mm) because I have 900 Frame.
  49. #199
    May 2014
    Anyone run into any issues with a 2014 or 2015 Fox Float CTD on a 2013 Scott Genius 940 (size 190mm x 50 mm)? Scott still won't provide any details when I contact them. I want to make this switch this summer. Otherwise, I will have to spend the money on an CC inline...
  50. #200
    I will recomend waiting for the cc inline much better shock
    And been on fox ctd genius 730 2013 no issues here
  1. genius 2013
    By sworksflux in forum Scott Sports
    Last Post: 08-06-2012, 04:23 PM
  2. Genius 2013
    By zedi in forum Scott Sports
    Last Post: 07-24-2012, 01:55 PM
  3. scott genius 2013 650b?
    By zombinate in forum 27.5
    Last Post: 07-05-2012, 07:12 AM
  4. Genius 10 shock leverage ratio replacement shock?
    By protocol_droid in forum Scott Sports
    Last Post: 11-01-2011, 06:24 PM
  5. 06 genius shock pressures
    By superspec in forum Scott Sports
    Last Post: 05-01-2011, 04:59 PM
