Page 2 of 3 FirstFirst 123 LastLast
Results 101 to 200 of 238
  1. #101
    Nov 2013
    I dont know if its possible I always wanted to get the twinlock off but you can ask fox directly.
    What i can say its that fox rear shock float ctd is f***ing awesome Im loving my bike now its really 150 travel machine. Swaping the dt swiss is was the best call for me.
  2. #102
    Reputation: stephanmoll's Avatar
    Re: Fox shock on 2013 Genius
    Finally my fox ctdFox shock on 2013 Genius-uploadfromtaptalk1390876496546.jpg
    Sent from my GT-I9300 using Tapatalk
  3. #103
    Nov 2013
    Yeah thats great.......
  4. #104
    Ready to gooooo finally goin to try it tommorowFox shock on 2013 Genius-uploadfromtaptalk1390938971978.jpg
  5. #105
    Nov 2013
    Looking good....
  6. #106
    Reputation: brentos's Avatar
    Going to try out a RockShox Monarch RT3.
    Tune: MM (S)
    Compression Damping: Medium
    Rebound Damping: Medium
    Threshold: Soft
    I was planning to get a shim stack with a Firm threshold, with possibly a Low compression tune, but this one feels really good and I don't notice any pedal induced bob when cranking it out on the flats (road).
    Also: I stated elsewhere that the shock hardware was 22mm x 8 mm. I was wrong, I remeasured and got 22.2x8.
    Ride report to follow once I find some dirt...
  7. #107
    Sep 2013
    The Monarch looks really good!
  8. #108
    Nov 2013
    That monarch looks good.
    Hit the trail and tell us how it handle.....
  9. #109
    Oct 2012
    So do I understand correctly, if I swap out my DT shock I will lose the Twin Lock device? Is it possible to use the Fox lever set up? Does Fox sell the lever and rear shock together?
  10. #110
    Nov 2013
    Fox has a remote lever but I dont know if its possible to set it up with the twinlock....
    I'm happy with no twinlock it was to much cables....
  11. #111
    Update: Got 20 miles in this morning, 3000' climbing, in a mix of snow/ice/dirt. About 26 Degrees. I weigh 155 lb, and had about 15 lb worth of shoes/clothes/lights/pack. I run a 140 mm Pike RCT3 up front, 51mm offset.
    Shock Model:
    2014 Monarch RT3
    Tune:
    Rebound: Medium
    Compression: Medium
    Threshold Tune: Soft
    Air Spring Pressure: 120 PSI
    Overall, the Monarch is quite impressive.
    • Chassis stability it phenomenal, with a “quieter” ride at the same time than the DT Nude, less upset by quick impacts.
    • The pedal mode seems pretty effective, this is a soft threshold tune…I might be wishing for a firm threshold tune. But as it is, turning it to “pedal” has almost no effect on bump absorption, and is effective for seated climbing. Standing overwhelms it though. Actually a great "set and forget" setting. Lock is not fully locked, but would be a great setting for extended climbs, it does hold the back end of the bike up a bit more than "pedal"
    • I’m most impressed with its ability to feel firm when needed, and really open up on the smallest of high speed hits...pedalling at low speed, I found myself thinking that a low compression tune would be better at speed, but once the speed picks up, it's perfect. Just as I want it at both slower speeds and faster speeds. Med. compression tune is for sure the way to go.
    • Med Rebound or light rebound would both work for my weight and shock pressure. Could probably go light on the rebound with good results too. I had it turned all the way fast on this morning’s ride in cold temps, but wasn't wishing for faster rebound…
    I do miss the adjustable travel and geometry a bit though...it sits back a bit more when climbing than the "traction mode" on the DT, but not by much. I will likely adjust my saddle position to accommodate, and possibly lower the bar a touch. Also lost about 50 grams to the DT Nude shock/remote setup.
  12. #112
    Reputation: biggazu's Avatar
    Dec 2008
    Hi Gary,
    I’m unsure on other Fox shock models and fitting would be at your own risk to your frame/damage, the fox shocks on the 2014 Genius will not fit previous frames as the head of the shock is bigger and may come into contact with the underside of the frame in use (may seem fine if tested in the stand)
    We do not recommend you fit the fox shock,
    Rind regards
    Gareth Clutton
    Warranty & Aftersales Manager
    SCOTT SPORTS SA (UK Branch)
  13. #113
    Dec 2008
    Hi again, What size is the mounting kit for the Scott Genius 2013 for a fox shock, Please.
  14. #114
    Nov 2013
    Quote Originally Posted by biggazu View Post
    If you have a genius 650B you need hardware 8x22mm
  15. #115
    Dec 2008
    Many thanks Mike.
  16. #116
    I think you may be able to get around the issue of the Fox Nude fouling the frame, by fitting an offset bushing, hence moving the shock body away from the bottom of the top tube.
  17. #117
    Dec 2008
    Scott Genius 740 Fox CTD Factory 2013
    Quote Originally Posted by cws196 View Post
    This is mine, Fantasic
    Attached Thumbnails Attached Thumbnails Fox shock on 2013 Genius-dsc_0019.jpg
  18. #118
    I have a Genius 900 SL with a Nude 2 and 2014 FOX Talas 34 CTD 140 Remote, I would like swap the NUDE 2 with the FLOAT X Remote or FLOAT CDT Boost Valve Remote. What would be the differences between FLOAT X and the Boost valve.? What size is the mounting Kit or reducers for the 900 SL?
  19. #119
    The float x has a piggy back that serves for long dh performance i think and mor coil feel of the shock. I have the boost valve fox on my genius but think makes better bottom in out of the shock.
  20. #120
    Nov 2013
    if I had the money when I made the swap no question would have gone with the Float X well for genius 29er I dont have the measure but there is a 29er here that swapped to Cane creek maybe he will help you when he reads the forum....
  21. #121
    Yup cane creek has awsome feedbacks better check it out and its almost the same price as fox
  22. #122
    Nov 2013
    Great it work..........now its really 150 travel...
  23. #123
    Dec 2008
    Quote Originally Posted by MikeQueyar View Post
    Not had a ride out on the genius as yet. Weather in the UK is wet wet wet at the moment.
    Only other thing im going to order for the shock, is the air volume kit.
    ThenI can lower the psi in the shock body, and also get a little more ramp up in the end travel. The garage test, the bike is very plush. NOW.
    I got the shock cheap ish off ebay, brand new. Happy Days
  24. #124
    Nov 2013
    hey did you check the fox recall for your 34 evolution??
    Model Year 2013 Evolution Series Voluntary Recall | FOX
    My fork is part of the recall and Fox has shipped the 2014 damper fit so that I can repair it and Free.....lol thats great because I actually was planning on buying the dampers and they were $260.00 plus tax.....now I getting the upgrade for free.
  25. #125
    Ur lucky mine was not in the recall lol, have to wait for an excuse to swap it for the new xfusion sweep!!
  26. #126
    Nov 2013
    I was reading on pinkbikes some reviews and comments that the 2013 evolution series with the new dampers has a really good performance some even said is good as the pike.
    I havent try the pike and im waiting the damper to arrive set them up and try their performance in the trails.....
  27. #127
    First enduro on new fox shock whaaaatt a difference so plush!!!!! What a differenceFox shock on 2013 Genius-uploadfromtaptalk1392590900797.jpg
  28. #128
    Feb 2014
    Been watching this thread now and some very good ideas to the shock probs on the genius.Mines ok at the moment and ive got used to the none plush shock after riding a lot of hardtails,so until its time to change ive put a lizard skins shock cover over the dt nude shock so no one can see it.Its the cheap option,but what about an x fusion shock as the new ones been getting good reviews now and there a good price.
  29. #129
    Would think be nice too i am looking at the new fork from them yhe sweep
  30. #130
    Nov 2013
    I want a PIKE 160mm haahaha
  31. #131
    Me too but too damn $$$$ and read on what mountain bike that the perform the same
  32. #132
    Nov 2013
    Yeah a would better get a new frame before a new fork anyway Im waiting the 2014 dampers for my evolution fork.
  33. #133
    I just place an order of a Fox Float X CTD Remote for my Genuis 900 SL. Hope everything goes smooth. I will show some pictures of the swap.
  34. #134
    Niceee !!!!!
  35. #135
    Nov 2013
    Yeah \m/ wont regret doing the shock upgrade.
    Waiting for the pics of that X.....
  36. #136
    Finally the Float X arrived. I talked to the guys at Universal Cycles, and they help me out with everything (I recommend these guys are very helpful).
    So From here:
    To here:
  37. #137
    Just Photos: If you have any Qs please let me know
    Attached Thumbnails Attached Thumbnails Fox shock on 2013 Genius-float-x-genuis-900sl-02.jpg
  38. #138
    Nov 2013
    \m/ rock on!!!! Really nice....
  39. #139
    Some assembly pics:
    Fox shock on 2013 Genius-float-x-genuis-900sl-08.jpgFox shock on 2013 Genius-float-x-genuis-900sl-10.jpgFox shock on 2013 Genius-float-x-genuis-900sl-11.jpgFox shock on 2013 Genius-float-x-genuis-900sl-13.jpgFox shock on 2013 Genius-float-x-genuis-900sl-14.jpgFox shock on 2013 Genius-float-x-genuis-900sl-15.jpg
  40. #140
    That looks REALLY good!
    No clearance issues then, with the mainframe-end, when the shock is fully compressed? The issue that Scott warn about when using Fox shocks with a pre-2014 frame is that under severe force/frame-flex, the shock 'head' can contact the underside of the toptube.
  41. #141
    Nov 2013
    I been using a fox ctd and no problem here.
    <iframe src="//player.vimeo.com/video/88174136" width="500" height="281" frameborder="0" webkitallowfullscreen mozallowfullscreen allowfullscreen></iframe> <p><a href="http://vimeo.com/88174136">Dandole al pedal....trying Gopro3+ silver</a> from <a href="http://vimeo.com/user19520775">Miguel Cuellar</a> on <a href="https://vimeo.com">Vimeo</a>.</p>
    That float x looks sexy so have you ride it yet??
  42. #142
    Plenty of clearance, the head of the shock almost doesn't move when it is under full compress. I don't know about the severe force/frame-flex though. Time will tell.Fox shock on 2013 Genius-float-x-genuis-900sl-22.jpgFox shock on 2013 Genius-float-x-genuis-900sl-23.jpg
  43. #143
    Nov 2013
    hvmathews... thanks for the pictures. I've hardly rode my '13 740, and these pictures helped me move up a rear shock upgrade on my to do list.
    I assume this meant (and what you said upthread about your fork) you had to abandon the twinloc system. I'm a bit of a neophyte, so excuse the possibly dumb question, but do you have two remotes on your bars?
  44. #144
    Nov 2013
    MQ, another neophyte question coming up...
    Why do you have those two cylinders on the rear frame part (seat stays?)?
  45. #145
    Nov 2013
    When i get out of my house to the trial i need to pedal 5km in the street and around 5 or 5:30am and its still dark so they are reflective bands.
  46. #146
    Nov 2013
    Got it.. thanks. Nice video by the way.
  47. #147
    Nov 2013
    Quote Originally Posted by Hextall View Post
    Thanks....
  48. #148
    I will have just one remote.... with the spliter (Dual Cable Fork and Shock)the fork has to be a 2014 also in order to work in conjunction with the shock. Fortunately I have a 2014 Fox Talas. I will show some pics as soon as I finish. Meanwhile this link shows how it works
    2014 CTD Remote Installation | Bike Help Center | FOX
  49. #149
    Nov 2013
    Thanks for the info.. I've saved it all, and look forward to your setup.
  50. #150
    Bonking ... not feelin' well The Fox Float X story
    Finally I got some riding today 20+ miles of a fast trail here in South Florida I love the way the bike is cornering and in the technical section was way better than with the old shock, It feels more plushy (smooth), reliable and stable.
    At the end of the ride something went wrong with the internals at the shock remote level. The shock is not returning from the Trial position to the down position. I spoke to the guys at Universal Cycles, but I will have to return the shock for inspection, bad news for now. The return pulley looks very weak, maybe the return spring is bad. I will keep posting how this shock swap story develops, at least 3 weeks more.
  51. #151
    Dec 2008
    A little update, I now have a fox ctd remote 2013 shock,
    Which works better than the DT Swiss with the twinloc.
    So the question is, why does Scott not want you to do this upgrade. Mojo suspension said it would fit, wouldn't hit the down tube and would work fine
    with the twinloc!!!!!!Fox shock on 2013 Genius-1970408_10203264119822846_1385986765_n.jpg
  52. #152
    Nov 2013
    Rock on \m/
  53. #153
    Nice !!!
  54. #154
    Nov 2013
    Biggazu, you got this shock to work with the twinloc?
  55. #155
    Dec 2008
    Yes, it works a treat, bit too easy to mount and setup, Was a doddle.
    Keep thinking ive done some thing wrong. cycled thru all the settings on
    twinloc and it just works better than the dt swiss.
  56. #156
    Feb 2014
    Amazing,did you have to change the disc in the twinloc from DT Swiss to a Fox one.
  57. #157
    Dec 2008
    Quote Originally Posted by wock View Post
    Done nothing to the fox ctd. Just threaded the cable,
    Took up the slack. That's it.
  58. #158
    Feb 2014
    how much for the remote ctd shock.
  59. #159
    Reputation: Rhinodriver's Avatar
    Feb 2014
    What size was the shock and hardware? Looks great. I'd like to use the same setup.
  60. #160
    Dec 2008
    ... and if we just ...
    Quote Originally Posted by Rhinodriver View Post
    The Fox Float CTD is a 200 x 57mm with a medium tune and 175 psi boostvalve.
    bushing are 8x22mm which my good friend on here Mike told me to buy. other than that, that's it, New inner and outer cables help. Mine are on order.
    Plus I did a 20.7 mile ride Garmin Connect
    The bike was SWEAR WORD EPIC EPIC EPIC. It rides just like it was designed to do, and very very well. The shock was a lot of uk sterling. But worth as much as a very good set of wheel. The climb mode with the high compression is way better than having the shock locked fully out. Plus the decent open mode is also like coil spring smooth. Worth ever £££££ Why on earth Scott didn't put the fox CTD Float shock on from new is blinding.
  61. #161
    Feb 2014
    Thanks man! Glad to hear it rides so good... Now to figure out how to pay for it.... Not sure my moonlighting as a slightly overweight, middle aged, bald gigolo is going to get me there!
  62. #162
    Nov 2013
    I had budget trouble too so I got a 2013 float CTD on sale for 258 on probikesupply and it works great Im hitting the trail really good with that shock.
    If I had the cash I would go for the fox float x but the ctd work just fine....
  63. #163
    Dec 2013
    Hi!
    Great info!
    First post in this Great forum!
    Got inspired and bought a Fox float CTD 2014 of ebay
    yesterday. 225$ incl shipping. Hope this shock will work
    better than stock on my 740...
    Mods done so far:
    Richey carbon riser bar
    Xt brakes and gearshifters
    Converted wheels tubless
    Tmars dropper post
  64. #164
    Good price I got my ctd kashima at 300 and what a diference.
  65. #165
    Nov 2013
    Quote Originally Posted by abris76 View Post
    Hi!
    Great info!
    if you ordered the 200x57mm and hardware 8x22mm there will be no problem and you will have a better bike....
  66. #166
    Dec 2008
    Hi!
    Great info!
    Mods done so far:
    Tmars dropper post
    If you not smiling like Bill Gate when he checks his bank balance, some thing is wrong.
    That's how good the bike is with the Fox shock.
  67. #167
    I'm not sure why Scott UK advise against fitting a Fox shock. There must be a reason (perhaps an issue on smaller sizes?). Perhaps the odds of the shock head hitting the underside of the top tube are VERY slim, but tests proved that with all the worst-case scenarios it may happen ie small frame, large rider, frame flex etc etc. They can't say it will work for this and not for that, otherwise they open themselves up to all the legal rubbish.....
    Anyway biggazu - are you in the UK as well?
  68. #168
    Dec 2013
    That what's I'm hoping!
    Got 200*57 incl correct spacers.
    Was unused, came of a Bronson...
    Just wait and see.
  69. #169
    Dec 2008
    I did get an answer from Scott UK, the reply is on the forum. The Fox Nude shock off the 2014 won't fit, The head of the shock might hit the top tube. I didn't fit a nude, I took advise from Mojo fox. The Fox float ctd I installed has a lot of clearance, I would not risk it if it wouldn't work. Funny how many pro riders have Scott genius, but none use the DT Swiss shock!!!!
    If you look at the picture above, you can see what sort space between the shock and the down tube, it had less with the dt swiss.
  70. #170
    Feb 2014
    Im in the UK. CWS.
    Live in the Forest Of Dean.
  71. #171
    Apr 2014
    Hi
    Would the set up you describe work on a genius 940 ? I would love to change my Swiss DT shock for something that works as I love the bike.
    Steve
  72. #172
    Quote Originally Posted by Oldjoe sew View Post
    Hi
    Steve
    I have a 900 SL which geometry is the same as the 940. I installed the Float X without any trouble, fits perfect, I had a problem with the return spring on the shock but Fox took care of it and now the shock is working as planned. I'm using the twinlock system, not the Fox CTD remote lever, the riding is unbelievable better. You won't regret it....
  73. #173
    Apr 2014
    Goodbye fit swiss rear shock
    Quote Originally Posted by hvmathews View Post
    Thanks will get looking for one
  74. #174
    May 2014
    Hey folks, so glad I came across this post. Have a 2013 Scott Genius 740 which I have customised a fair amount (X01 Groupset, reverb, Hope brakes etc) and have now turned my attention to the shock.
    Can I just confirm that it's a 200x57 shock I need rather than a 200x51?
    Checking the Cane Creek website, they have suggested the latter due to the possible issue with frame strikes at full compression but reading the posts, it seems 200x57 is fine.
    Will be going with a Monarch+ shock rather than the CC and will pair that with a Pike up front but want to ensure I get the right one. Would it make a huge impact if I went with the recommended 200x51 size or are CC just playing it safe.
    Thanks folks
  75. #175
    Thats correct 200/57 why no cane creek there is another forim of a genius 930 with one an no problem?
    I went with fox boost valve ctd and perfect fit.
  76. #176
    Nov 2013
    I made the swap to a genius 740 shock 200x57mm and hardware 8x22mm i went with a fox ctd but for rockshox they should not change.
  77. #177
    May 2014
    Quote Originally Posted by stephanmoll View Post
    Thanks for taking the time in responding, good to know. Have a great weekend.
  78. #178
    OK, so if I have a 2013 Scott Genius 930 (29er), what size Fox rear shock would I need? I am seeing the whole 29er and 650b back and forth conversations since the beginning of this thread and have become thoroughly confused now... I just want to make absolutely sure that if I pull the trigger I am buying the correct shock... Ideally would like the Float X CTD, but would be fine with a lesser model depending on budget.
    My searching for DT Swiss support for seal kits or maintenance instructions have become more frustrating than they are worth, so this is my next best option.
    Thanks for any input!
    2011 C-Dale Flash 1 650b
    2015 Charge Cooker Maxi
  79. #179
    Yes it sucks dt swiss, in my opinion wait for cane creek inline I have the fox ctd factory and feel to lineal and goin to make a swap to cane creek.
  80. #180
    Reputation: weaverwins's Avatar
    Dec 2008
    Quote Originally Posted by A-Ray View Post
    this email is from fox sometimes last year when i asked the same question of them for my 2013 genius 910. i ended up going with the cane creek db air cs but the float x looks awesome too.
    With that bike you can fit any of our air rear shocks. As far as remote goes you can get either the FLOAT CTD Remote at $470.00, or you can get the FLOAT X for $595.00. The price for both of these is without the remote. The size of that shock is 7.5” x 2.0”.
    Scott Genius 910 tricked out as much as I could without getting a divorce
  81. #181
    Nov 2013
    You changing again bro.....Im making a frame swap the bronson will arrive by the end of this month.
    Are you selling the fox ctd kashima??? I may be interested on buying it the measure are the same for the bronson 200*57
  82. #182
    Yes I am selling it!!!!
  83. #183
    No way I am looking at a bronson frame too were u abke to sell your scott frame quick?
  84. #184
    Quote Originally Posted by weaverwins View Post
    Thanks for the great info! Looks like I will be going this route...
  85. #185
    Hi guys, I'm looking to do this swap on my 710 (2013). Sorry to beat a dead horse here, but can you confirm the shock hardware size and shock length? The Scott manual for the 2013 Genius shows 6x22.2 hardware and 200x55 shock length (which probably translates to 200x57 (7.875 x 2.25) for the Fox CTD), but the thread seems to say 8x22 is the size.
    Where's a good source for the hardware?
    TIA.
    Here's a screenshot from the manual:
    ShockWiz Rentals available at FeelTheBerm.com! Into Vintage? Check out my Rock Shox Judy XC/SL/FSX Decal Sets
  86. #186
    I got my hardware on jensonusa.com 22.2 x 8 but my genius is 730 though
  87. #187
    Interesting, I wonder if the carbon vs aluminum frames have different spacing then? The manual I picked up that information from seemed to cover both versions, however. Thanks for the tip for jensons!
  88. #188
    Dec 2008
    Quote Originally Posted by bryanus View Post
    Contact fox (or cane Creek etc) and they'll tell you which shock fits.
  89. #189
    Nov 2013
    My was 200x57 and hardware 22x8
    I sole my to a friend and he hasnt had any problem untill this day.
  90. #190
    May 2013
    Anyone else considering the Cane Creek Inline?
    The reviews seem to be pretty favorable on Cane Creek's new DB Inline shock and seeing how its the only Cane Creek model that will fit my 940 Genius, any opinions?
    2012 GT Karakoram
    2013 Scott Genius 940
  91. #191
    Dec 2008
    Quote Originally Posted by Rogue426 View Post
    i might have gotten that for my 910 had it been out. ive heard that unless youre doing extended downhill runs, the piggyback isn't a bonus. couldnt be happier with my CC DB Air CS as it completely transformed my genius and made it ride how i hoped it would out of the box but like i said, the inline wasnt an option at the time.
  92. #192
    Yes the inline seems solid I am goin to swap my ctd for cane creek.
  93. #193
    May 2013
    Do you know how many sets of 8x22mm bushings are needed? 2? One for the piston side and one for the Chamber side?
  94. #194
    2 sets
  95. #195
    May 2013
    May 2013
    Just verified with Scott the the shock dimensions for the Genius 700 SL is 200mmx55mm
  97. #197
    What shock cane creek?
  98. #198
    If you take a look at the Genius 2013 Owner's Manual it shows that Genuis 700 and Genuis 900 are different regarding the size of the shock
    http://assets.scott-sports.com.s3.am..._Genius_EN.pdf
    I bought the 7.5 x 2.0 (190mmx50mm) because I have 900 Frame.
  99. #199
    May 2014
    Anyone run into any issues with a 2014 or 2015 Fox Float CTD on a 2013 Scott Genius 940 (size 190mm x 50 mm)? Scott still won't provide any details when I contact them. I want to make this switch this summer. Otherwise, I will have to spend the money on an CC inline...
  100. #200
    I will recomend waiting for the cc inline much better shock
    And been on fox ctd genius 730 2013 no issues here
  1. genius 2013
    By sworksflux in forum Scott Sports
    Last Post: 08-06-2012, 03:23 PM
  2. Genius 2013
    By zedi in forum Scott Sports
    Last Post: 07-24-2012, 12:55 PM
  3. scott genius 2013 650b?
    By zombinate in forum 27.5
    Last Post: 07-05-2012, 06:12 AM
  4. Genius 10 shock leverage ratio replacement shock?
    By protocol_droid in forum Scott Sports
    Last Post: 11-01-2011, 05:24 PM
  5. 06 genius shock pressures
    By superspec in forum Scott Sports
    Last Post: 05-01-2011, 03:59 PM
