Results 1 to 6 of 6
    Reputation: Krunk_Kracker's Avatar
    Dec 2012
    A few questions regarding the CTD Fox Float 32
    Just picked up a 2013 Scott Scale 740, and so far I love it.
    I just have a few questions regarding the CTD setup on the Float 32 Evolution.
    I've been perusing this part of the Fox site - WebHelp and have found a lot of answer to questions that I had. One thing I'm not sure about, is how much movement exactly should there be in climb mode? I understand that it's not a traditional lock out, but there's not any explanation if there should be less movement, or just slower response. I read that there is a blow-off valve in case theres a big hit in climb mode, which leads me to believe that there should be less movement. I've googled and searched everywhere, and some people are saying 1 to 2 inches of movement while in climb mode, while others are saying it's the same movement as the rest, just with much stiffer and slower response.
    Does anyone have a definite answer to this? I've adjusted the barrel adjuster on my remote, and I can easily make the Climb mode only have about 2" of travel, or I can make it just feel really stiff, I just need to know how it is intended to operate.
    2014 Scott Scale 740
    Dec 2012
    No one has any input?
    Reputation: ktm520's Avatar
    Cable needs adjustment or damper is low on fluid. It should be ridiculously firm. There is no magical travel figure. Its a spring loaded hydraulic valve when fully in climb mode.
    Nov 2013
    On my genius 740 climb mode is full lock, trail mode is my favorite i feel more traction even for climbing and descend is full 150travel very plush.....
    Dec 2012
    I think I've settled with what both of you have said.
    My fork never fully locks out, but it is extremely stiff in climb mode.
    It won't be a full rigid lockout, but super stiff. Like I said, its a heavily spring loaded valve. Once pressure rises enough to open the valve, the fork will compress. Purely a function of load. The biggest draw back of the evo fork is the lack of a shimmed reb piston, just a simple orifice damper. Major fail on Fox's part, as the fork it replacee (old open bath, "o/b") was a shimmed damper.
  1. Rear Fox Float CTD Noob Questions
    By HoustonHT in forum Shocks and Suspension
    Last Post: 12-10-2013, 02:06 PM
  2. X-post: Rear Fox Float CTD Noob Questions
    By HoustonHT in forum Giant
    Last Post: 12-10-2013, 02:04 PM
  3. Replies: 5
    Last Post: 07-16-2013, 02:37 AM
  4. Replies: 4
    Last Post: 08-07-2012, 02:24 PM
  5. Fox Float R questions
    By Mr. D in forum Shocks and Suspension
    Last Post: 04-10-2011, 06:49 AM
